FXR Front Wheel Swap Speedo Drive Prob/?
Old May 9, 2012 | 01:24 PM
bwtc83's Avatar
bwtc83
1st Gear
Default FXR Front Wheel Swap Speedo Drive Prob/?
I wanted to swap out a 21" harley mag wheel, off a sporty, that my buddy had lying around for the 19" mag that came on my bike. They are both 3/4" axle for narrowglide front ends and the brake lined up fine, but the bearing/spacer (?) on the sporty rim didnt have the recess to fit the speedo drive.
I can swap the brakes to accommodate the speedo drive tang, but does the whole bearing/spacer assembly have to be swapped? I know the speedo will be a little off but Im not concerned.
FXR wheel
Sporty wheel
This is what it looked like. Im not sold, I think Im going to look for a 21" spoked front rim. I have some time since I dont have a bearing puller if the assembly has to be swapped. Its way easier to find one off a sporty, but Ill still have to deal with the speedo drive issue.
thanks!
Old May 9, 2012 | 03:55 PM
Progas99's Avatar
Progas99
Yes you can swap the brake rotors. Then pull just the spacer out from the seal and you should be able to put the speedo drive in place of it.
Old May 9, 2012 | 04:45 PM
SportsterBob's Avatar
SportsterBob
Does the front wheel assy with the speedo drive you have fit into your lower fork legs?
Old May 9, 2012 | 05:05 PM
bwtc83's Avatar
bwtc83
1st Gear
Progas - On the speedo side of the sporty wheel (pic 2) there is no spacer, just the bearing. It looks like a sealed bearing. There is no spacer.
Sportsterbob - the speedo drive sits in a recess on the bearing, theres no recess on the fork for it to fit into.
Old May 9, 2012 | 05:43 PM
SportsterBob
I think I know what you mean...The speedo drive is a spacer and there are different widths of speedo drives available. You'll have to figure out which width to get but it can be done! There is no recess on either of the lower legs.
http://www.jpcycles.com/search/searc...text=0&Ntk=All
Old May 9, 2012 | 05:50 PM
Progas99's Avatar
Progas99
A sealed 3/4" bearing? I didn't know HD used them. If the bearing bore is deep enough, you might be able to use a shorter inner spacer to move the bearing in or use the earlier cup,cone and seal set up like your old wheel.
Old May 10, 2012 | 10:01 AM
grbrown's Avatar
grbrown
Wink
Harley used them on some models from around 2002. The easy way to compare wheels with tapered rollers and the later ones is to measure the hole in the centre of the rotor. Later rotors have a larger diameter hole and the wheel in the lower pic does look like a sealed bearing version.
Old May 11, 2012 | 09:10 AM
Progas99's Avatar
Progas99
Oh yea, I see that in the picture. So the old rotor won't fit. Personally, unless you're after looks only, I swapped the 21" on my FXLR for a 19"and I think it handles alot better.
Bcoish
EVO
Jan 23, 2019 10:37 AM
natural gasser
EVO
May 6, 2017 06:46 PM
trampsinger
EVO
Oct 21, 2014 05:40 AM
skarecrow
Apr 27, 2012 11:36 AM
tricone
Shovelhead
May 10, 2007 01:12 PM
