[size=16px]I have an 88 FXR that keeps burning up my ignition modules should I change over to a external ignition module? Or spend a lot more money on a more advanced internal ignition module and have you checked the charging system?[/size]
What kind of ignition have you been running? I like to have my modules out of the cone away from the heat
Hi I am new to owning a 71 shovelhead n it has one of these on it. I m looking for the usb programing wire for the ultima ignition 53-644 n web site to program it. I have been around Harleys all my life n never see this or learned how to work it..please can u help
Here yah go, however, this guy no longer sells the data cable. I did see some instructions (google search) on how to make your own but you need a little electronics know how to build one:
If you can't find a cable, (check dynatek you need the programming software and cable for the 2000i if they are still made). The program is called curvemaker. Without the program, you still have 4 pre-programmed advance curves to choose from. You can use the different curves by playing with the switches and even rotating the ignition to alter those cureves a little:
