tomorrow is sunday, and need fluids...
Old May 19, 2012 | 08:15 PM
jsbridgew's Avatar
jsbridgew
Default tomorrow is sunday, and need fluids...
didn't make it to dealer in time today....too busy trying to find tranny problem
anyway, i need primary and tranny fluid....any suggestions for something from autozone?
Old May 19, 2012 | 08:32 PM
badcooky's Avatar
badcooky
OIL thread warning.
Old May 19, 2012 | 08:36 PM
NAILIT RK's Avatar
NAILIT RK
I run Mobile 1 V-twin in the primary and crankcase. Mobile 1 75-90 weight In the trans
Old May 19, 2012 | 08:38 PM
NAILIT RK's Avatar
NAILIT RK
FYI. The mobile 1 V- twin is not kept with the car oils. Ask the clerk as they keep it separate
Old May 19, 2012 | 08:44 PM
Jim Kraft's Avatar
Jim Kraft
Any 10-40 motor oil will work fine in the primary, and about any 75-90 gear lube will work fine in the transmission. I run Harley Formula Plus when I think to get it when I am there. Otherwise, the above works just fine.
Old May 19, 2012 | 08:46 PM
Inspector 12's Avatar
Inspector 12
Walmart here in town carries Mobil 1 V Twin in both of the stores. They keep it over by the automotive section.
Old May 20, 2012 | 01:14 AM
Shredding rubber's Avatar
Shredding rubber
I use rotella 15w-40 diesel oil in the primary. I use it in my shared sump Honda bikes with no issues and have been using it in my primary since I got the bike. It has the JASO rating which means wet clutch safe.
You could use it for the tranny as well however I would use gear oil personally. Shockproof heavy is the best stuff out there. My Indy changed my tranny fluid when they put in the 106 and within 2000 miles the bikes shifting was notchy and clunked when going to first,neutral was tough to get into. Put the shockproof in last weekend and within 10 miles my tranny was back to being smooth again. I will never put motor oil in my tranny now that I have felt the difference.
Old May 20, 2012 | 02:41 AM
Honey-Badger's Avatar
Honey-Badger
Wallmart carries motorcycle oil. Mobil 1 vtwin syn, and another brand. Can't recall the other brand right now.
Old May 20, 2012 | 08:08 AM
Schex's Avatar
Schex
Mobil one 75w-140, in trans, less clunky
Old May 20, 2012 | 03:29 PM
1flhtk4me's Avatar
1flhtk4me
I bought my fluids at autozone yesterday.
Mobil 1 V-Twin for motor,Valvoline 20W50 MC oil for the primary and Valvoline 75/140 full syn. for the tranny.
