Surging
Old Jun 9, 2012 | 10:57 PM
ptcruiser's Avatar
ptcruiser
Default Surging
Hello I have 94 FLHTC tru-dual exaust ev13 cam single fire ignition stage 1 breather with CV carb w/ 185 main 46 slow jets new unmolested slide stock spring w/ 2 shims under stock needle. The problem im having is when in a low gear and rpm coming up coasting down hill throttle closed it surges as if your blipping the throttle. Other then this it runs out good.
Old Jun 9, 2012 | 11:38 PM
Jethro's Avatar
Jethro
As I remember-and remember, it's late at night and I'm having a beer-surging at low gear/low throttle settings is usually related to a lean condition, which also means you are probable using the slow jet, maybe some transfer ports open in transition. In the closed throttle you KNOW that it is the slow jet. Does the surging go away if you use the enrichener? If it does, then I would up my slow jet. I'm running a 48 and my bike is night and day compared to it's lean condition with the stock 42. I have the ev27 cam though, and higher compression pistons.
Old Jun 10, 2012 | 12:11 AM
ptcruiser's Avatar
ptcruiser
I havnt tried the enrichner I will do that next time I ride. I did have the 48 slow in for awhile and felt it was to rich as running around at low rpm my plugs got black so backed off to the 46 and I dont recall whether it did this surging with the 48 sounds like i may need to try it for expirmenting Thanks
gregjo1948
Aug 19, 2015 07:22 AM
bubba4u
EVO
11
Jun 14, 2011 09:30 PM
oldroadie
EVO
20
Aug 15, 2009 08:04 PM
the*bear
Exhaust System Topics
Sep 7, 2008 10:17 PM
twowheelsforever
Feb 26, 2007 09:33 AM
