Vibration
Old Jun 10, 2012 | 09:57 AM
chris jacob's Avatar
chris jacob
Default Vibration
Ok here's another question I'm sure has been asked before. How much engine vibration on an 88FXR should be normal. At 45 to 50 my eyes are a little blurry, and my hands feel like they're going to sleep. Had a new front motor mount put in, and looks fine.
Old Jun 10, 2012 | 12:50 PM
grbrown's Avatar
grbrown
Red face
That is not fine! Bike should be reasonably smooth throughout the rev range. You most certainly should not be getting bllurrrred vvissionn.
Difficult to know where to point you. Check the exhaust is not touching anything it shouldn't. It is mounted (or should be) to the engine/trans, so it moves with them. If you have a support to the frame for example, that will wreck your ride! There are rubber engine mounts at the rear as well, either end of the swingarm axle, so they may be shot. Another possible source of vibration is the handlebar mounts, which again are rubber.
Let us know what you find.
Old Jun 10, 2012 | 10:30 PM
Gunslingertom's Avatar
Gunslingertom
Dude needs to lay off the sauce before he rides.
Old Jun 11, 2012 | 04:54 AM
aaamax's Avatar
aaamax
Is this your first HD? Too the uninitiated, hogs often seem to vibrate too much.
Did the vibration increase after your new motor mount?
Old Jun 11, 2012 | 11:49 AM
ta2dup's Avatar
ta2dup
did the dyna line have rubber mount motor that year? my softail is still solid mount, slammed and straight piped and it rattles the ground for the people standing around also
Old Jun 11, 2012 | 03:17 PM
95yj's Avatar
95yj
All Softails are solid mount. The engine is actually part of the support of the frame. The TC's have a different engine for the Softails which are balanced. The Evo's don't which is why the Evo Softails have more vibration than the other Evos.
Old Jun 11, 2012 | 08:18 PM
chris jacob
Yes this my first HD. A friend of mine replace the front mount for me, but not the rear that I i guess are in the swing arm. Also not sure if the engine stabilizer has anything to do with it, but it looks like it's original. The vibration really tickles my nose so much that I can't get my visor up fast enough to scratch it
Old Jun 11, 2012 | 08:25 PM
a10182's Avatar
a10182
i would try someone other than your friend......
Old Jun 12, 2012 | 03:13 AM
grbrown's Avatar
grbrown
There are two stabilizers, one in front of the engine and the other between the heads. They have swivel joints at each end that should be free to move. If one had rusted solid I suspect it could cause vibration, but I also expect engine vibration would free it! The engine/trans weight is supported by the rubber mounts, the stabilizers only provide lateral support.
The rear mounts are at the end of the swingarm axle, between swingarm and frame, not inside the swingarm. Sounds like you could usefully get yourself a factory service manual! Essential bedtime reading. Not one of the cheap brands.
89FLHTC
EVO
29
Apr 29, 2016 05:37 PM
Scouser1
Apr 14, 2012 08:09 AM
Keys
Sep 8, 2011 07:37 PM
jhmp
Jan 2, 2008 08:32 PM
exhdo1
Sep 13, 2005 05:30 PM
