Old blue stranded me
Old Jun 14, 2012 | 12:36 AM
Spanners39's Avatar
Spanners39
Originally Posted by Owtlaw
If the virgins don't have to be chicks, you can probably score it at a Star Trek convention.
Old Jun 14, 2012 | 06:52 AM
Wakko47's Avatar
Wakko47
Hahahaha
Old Jun 14, 2012 | 11:16 AM
JohnnyC's Avatar
JohnnyC
I don't doubt you've checked the battery connections and possibly a portion of the ground connections that are easy to see and find. But if your headlight went out and back on, and the starter button worked, then didn't, then did, you obviously will have a primary power connection that is breaking contact.
Headlight and starters have some common power lines but the intermittent issues point toward something not making full or complete contact.
It may be a failing main breaker but I'm going to guess you still need to unhook each of the main power lines starting at the battery and continue to follow the line from point to point and disassemble the connections, thoroughly clean the surfaces, and reassemble using dielectric grease to aid in contact, and prevent future corrosion issues.
There may even be a major short, like a wire that has rubbed the frame and shorts out your electric system and kills everything simply occasionally.
It's a frustrating issue when it's intermittent. Whenever possible have it running as your manipulating wiring and see if you can duplicate the issue under test situations. Any arc or spark will show you exactly where the trouble is.
Good luck tracking it down.
Old Jun 14, 2012 | 11:27 AM
kdichs1015's Avatar
kdichs1015
I just went through this with my 01. Same symptoms, turned out to be the main breaker. It was shutting off every 2 minutes or so. Cleaned and tightened all ground and power connections, replaced the main breaker. Just got back from Texas on it, ran great.
I would suspect the main breaker first, if not that, the ignition switch, assuming you are losing power to everything like I was.
Old Jun 14, 2012 | 12:27 PM
grbrown's Avatar
grbrown
I had one of these wretched intermittent problems on another brand bike. When I turned on my indicator at speed, say to overtake another vehicle on a narrow road, the engine would cut! Didn't do it at slower town speeds.
Fortunately I have a friend who is a telephone service engineer and a marvel with electrics, but it still took him a couple of hours to track it down. Turned out to be a slightly loose join between two wires inside an insulating sleeve. Easy fix and no problems after that, but I had very little hair left!
Best of luck tracking yours down and fixing it.
Old Jun 14, 2012 | 08:42 PM
nyokie's Avatar
nyokie
Thanks lots of good suggestionsto get me started, hopefully it jumps out and bites me. I wanna get back on the road!
Old Jun 16, 2012 | 09:59 AM
nyokie's Avatar
nyokie
great news turns out 94-98 fl has a recall on the switch, relay, and main breaker looks like the dealer will be taking care of this 1 for free. you prob qualified for this too traildog? just go to mocos website and register your bike it will show recalls open and closed. if you still have the oem vacuum controlled tank valve that was recalled as well
Old Jun 16, 2012 | 02:01 PM
RidemyEVO's Avatar
RidemyEVO
I'm amazed that HD honors recalls for a bike so old. I wander how far back a year they would cover?
Old Jun 16, 2012 | 02:02 PM
traildog's Avatar
traildog
After all this time it would still be free? I'll call the stealership and check.
Old Jun 16, 2012 | 04:23 PM
nyokie's Avatar
nyokie
my dealer is honoring it. i think they have to honor any recall until it is fixed if it is a safety issue? losing complete power motoring down the highway sure aint safe
