fuel leakage
Old Jul 4, 2012 | 08:06 PM
machinehed's Avatar
machinehed
Default fuel leakage
1990 FLT Police .
CV carb.
Question ... newly purchased bike leaks fuel all over engine if fuel **** valve is not set to stop.???
Is this standard operating procedure for this bike .???
Dont have original owners manual.
Old Jul 4, 2012 | 08:50 PM
RidemyEVO's Avatar
RidemyEVO
Definately not normal, is it leaking from over flow at bottom of carb or from the petcock or possibly cross over hose or directly from fuel line?
Old Jul 4, 2012 | 08:54 PM
HarleyReece's Avatar
HarleyReece
I would say not. Where exactly does it look like its coming from? Check first to make sure the throttle cables, mainly the one that opens the throttle, and make sure there's enough slack to allow the throttle to fully close. I'd imagine if it's too tight fuel would leak.
Try to see if you can find where it's coming out of.
Old Jul 4, 2012 | 11:45 PM
hatchetman's Avatar
hatchetman
Most likely your float is stuck or you got some crap holding the float needle open. Pull the carb, flip it up side down & pull the bowl off. Clean it out, check the needle seat for crud. Than do a google search for the spec's to your carb & find out how many millimeters the float should be from the base of the bowl body. adjust & re install your carb.
Hatch.
Old Jul 5, 2012 | 06:20 AM
HarleyReece
Does the bike run normal? No bogging down when you jam on the throttle?
Old Jul 5, 2012 | 08:20 AM
miacycles's Avatar
miacycles
When the engine is off, the throttle position has no bearing on fuel other than opening and closing will cause the accelerator pump to give a shot of fuel. However if the throttle is stationary, no fuel will flow. Fuel flows into the engine because of the vacuum formed by the venturi. Check out your fuel line for crack, holes, or splits if the fuel is on top of the engine. Hope this helps.
John
Old Jul 5, 2012 | 03:26 PM
D1gger's Avatar
D1gger
If closing the petcock stops the leak, I would tend to think the problem would be from the petcock to the carb. I have seen petcocks leak, as well as the line from the petcock to the carb.
I wouldn't think it would be the crossover line if turning the valve off stops it.
Old Jul 5, 2012 | 03:37 PM
Spanners39's Avatar
Spanners39
11mm is the float height setting.
Old Jul 5, 2012 | 03:46 PM
HarleyGyrene's Avatar
HarleyGyrene
Ditch the vacuum petcock (do a search: nothing but problems !) and get a good Pingle that will last forever !
Old Jul 5, 2012 | 05:46 PM
GraemeR's Avatar
GraemeR
Question: Exactly where is the fuel coming out of? until we know that then its all random guessing.
88Heritage_classic
EVO
20
Nov 11, 2024 10:27 AM
Nilla
Aug 8, 2012 06:42 AM
boxfullofbluze
Nov 9, 2011 07:14 PM
oil leak
Exhaust System Topics
Aug 30, 2010 06:39 AM
jptaylor2
Jun 16, 2009 10:48 AM
