Quick Cam question, ev27
Old Jul 12, 2012 | 10:05 AM
lieutenant G's Avatar
lieutenant G
Default Quick Cam question, ev27
Im putting in an EV27 in my 98fxdl next week and what to know how to get everything lined up. I broke into the cam case about 5k ago and replaced the cam bearing and lifters and noticed that the OEM cam had two dots on it, which lined up with the breather gear and drive gear (bottom gear?) I hear the Andrews only has one dot so do i alighn that to the drive gear? then at what position does the breather gear go?
Old Jul 12, 2012 | 10:41 AM
Doug S's Avatar
Doug S
If your present gears are not making a whining noise then I would swap the existing cam gear to the new cam...Reduces the chance for noise and you'll have your two dots as well...LOL
Ds
Old Jul 12, 2012 | 10:56 AM
miacycles's Avatar
miacycles
Every cam, Andrews or others that I ever put in had two marks, some where dots some where lines.
John
Old Jul 12, 2012 | 05:08 PM
Spanners39's Avatar
Spanners39
Easiest just to use your existing cam wheel as you'll have to take it all apart again if the one on your cam is the wrong size. For how long it takes it isn't worth not doing it. The measuring system that comes with the instructions is a pain and takes longer than the wheel swap anyway.
Old Jul 13, 2012 | 08:56 AM
GraemeR's Avatar
GraemeR
The new cam will have two marks on it....so no worries
fxhawg85
General Topics/Tech Tips
Nov 9, 2017 03:00 PM
terrapin88
EVO
Apr 22, 2013 05:52 PM
Proud Marine Dad
EVO
Mar 28, 2013 04:40 PM
redrott
EVO
Jul 5, 2010 11:03 AM
Z
Exhaust System Topics
Dec 3, 2009 05:42 PM
