99 evo overheating
Old Jul 31, 2012 | 04:30 AM
99CMCevo's Avatar
99CMCevo
Stage III
Default 99 evo overheating
When I left for work one morning my bike started running rough, so a mile down the road I turned around. In the 2 mile trip my pipes turned a blue/purple color. From what I've looked up this means it's running lean. It's both pipes evenly. I replaced the rubber intake gaskets, and the little vaccum seal. I'm wondering if my carb brought up some debris, any second opinion would help. Thanks!
Old Jul 31, 2012 | 05:19 AM
Spanners39's Avatar
Spanners39
Retarded timing will do that too....check it hasn't slipped.
Old Jul 31, 2012 | 10:35 AM
miacycles's Avatar
miacycles
Check the timing first as it's the easiest. Just remove the cover and see if there is any indication of the plate moving. If not, then it's time to check the fuel system out. Look at the vents, fuel lines, petcock vacuum, and then the carb.
John
Old Jul 31, 2012 | 10:37 PM
swamperca's Avatar
swamperca
Maybe a vacuum leak making it lean, recheck the carb mount.
Old Aug 1, 2012 | 01:24 AM
99CMCevo's Avatar
99CMCevo
Stage III
It has a mechanical advance, and one of the springs is broke. I've gotta figure that's what is wrong. The accelerator pump needs replaced, but the carb was a lot cleaner than I expected. Thanks for your help. Don't ask why it has a mechanical advance
Old Aug 1, 2012 | 11:30 AM
1984_FXRT's Avatar
1984_FXRT
"Mechanical advance" on a '99 EVO? You don't have an electronic ignition?
Old Aug 2, 2012 | 05:00 AM
99CMCevo's Avatar
99CMCevo
Stage III
Yes, it is currently running on points and condenser. The ignition module quit on me completely, and left me stranded. I'm pretty happy with the the older ignition, until my recent problem, but at least it still got home under it's own power. I'm running the factory coil, and I still have the ignition module on it because that's what the coil bolts to. I will probably go back to the factory design, I just needed something to get me through the season.
Old Aug 2, 2012 | 07:30 AM
1984_FXRT's Avatar
1984_FXRT
Understood - as you've just become aware, an overly retarded ignition curve can indeed cause overheating. If you look on eBay - or ask here, you can probably find a stock ignition setup for the asking from someone who's gone aftermarket.
Old Aug 2, 2012 | 12:15 PM
Jim Kraft's Avatar
Jim Kraft
I changed my old 84 Sportster to points when the ign. module went bad on it, and I think it ran better than before. I did change to the points type coil as they do operate at a different secondary voltage. I carried a spare points and condenser with me, but I never needed it in 20,000 miles. At least if it did quit I could fix it, and it was $35.00 instead of $145.00.
Old Aug 2, 2012 | 12:20 PM
92FLHS's Avatar
92FLHS
If it is overheating Not to be funny but have you checked the oil tank for bubbles to make sure the pump is working?
just a thought
JDixon
Apr 30, 2017 02:24 PM
JohnnyRebKY
May 12, 2014 01:31 AM
houseoutnumbered
EVO
21
Mar 13, 2011 04:43 PM
G wood Todd
Exhaust System Topics
Aug 14, 2007 01:16 PM
csk24
Apr 23, 2007 12:02 PM
