shock question
Old Aug 22, 2012 | 07:53 PM
spanky02's Avatar
spanky02
Default shock question
are the shocks on my 96 super glide adjustable? i didnt see any adjustments on them. also what are the stock length? when i get new ones i would like to get shorter ones to drop the back end some
Old Aug 23, 2012 | 11:54 AM
grbrown's Avatar
grbrown
Depends which Super Glide you have, as I believe the Sport versions had taller suspension than the others. I would guess the tall ones were 13" and others 12". If you jack your bike up so the rear wheel just clears the ground you can measure yours, from eye to eye.
Be aware that using shorter shocks usually reduces available shock travel and is also likely to reduce ride quality.
Old Aug 24, 2012 | 12:00 AM
EVOrider's Avatar
EVOrider
The stock one on the Low Rider and the ones on the Dyna Convertible were all adjustable. They make a small spanner wrench for adjustments.
I would think very hard about lowering the bike as well. The stock shocks are soft enough and will bottom out from time to time. In my opinion, these bikes are low enough. Hit the right bump and you'll be wishing you had the taller shocks back.
Old Aug 24, 2012 | 06:53 AM
Wakko47's Avatar
Wakko47
The shocks on my '96 Low Rider don't appear adjustable to me...would they have the same big collar that my '90 Sporty had?
While resting on the jiffy stand, my shocks are 12.5" eye to eye. My plans are to replace them with touring air shocks and see how it goes.
Old Aug 24, 2012 | 08:57 AM
EVOrider's Avatar
EVOrider
On my '98 Low Rider, you adjust the rear shocks at the bottom of the shock. There are small holes through the chrome, the end points of the spanner wrench goes through and then you simply turn. Mine are still stock...I assume the '96 year model would be the same. Wonder if you have aftermarket?
Old Aug 24, 2012 | 09:58 AM
Wakko47's Avatar
Wakko47
Hmmm, I wondered what those holes were for. I wonder what mine are set for? It bottoms out super easy and I'm only 170#.
Rustyg500
Sep 6, 2018 03:05 PM
drxw
Sep 14, 2017 04:13 PM
Bleachey
EVO
Mar 24, 2012 12:50 PM
gstep51
Sep 7, 2009 10:52 AM
06WideGlide
Mar 7, 2007 10:22 PM
