EV13 Cam
Old Aug 26, 2012 | 07:21 PM
shovelhead FXEF's Avatar
shovelhead FXEF
Default EV13 Cam
was looking to instal EV13 in my 1995 Ultra. Does anybody have any experience using this cam in a heavy bagger? I would like even a little more low end than my stock cam. Engine has 46K miles, so i'm looking to re-do the cam, bearings and the top end
Old Aug 26, 2012 | 08:01 PM
badcooky's Avatar
badcooky
Apparently It's a good little cam,you will pick up bottom to mid but aIt's little flat up top.
Old Aug 26, 2012 | 08:11 PM
shovelhead FXEF
Is it a worth while upgrade from the stock cam? I usually only tach up to 3500 on the highway. I don't want to make a parallel move from stock.
Old Aug 26, 2012 | 08:43 PM
Jclind1966's Avatar
Jclind1966
I've got the EV13 it give a nice boost in the midrange
Old Aug 26, 2012 | 09:38 PM
Schex's Avatar
Schex
I'm planning on that cam for my Ultra too, since it rarely sees over 4000.
Old Aug 26, 2012 | 10:48 PM
LowriderHarold's Avatar
LowriderHarold
Default I think it is
Can't say for a bagger, but dry weight of my Lowrider is 598 lbs, I go 230lbs, & my ole lady is 180lbs. Do the math. Pulls great to about 3500-4000rpms. Great torque around town. Why I chose this cam. Wanted the torque for 2 up riding, & sweet spot is about 80mph/3250rpms out on the interstate, stock gearing. Average about 36-37 mpg. I put all other upgrade info on my garage page. I like it.
Ride Safe,
Harold
Old Aug 27, 2012 | 09:01 AM
StuxnetKiller's Avatar
StuxnetKiller
You'll find a lot of info on that subject here and the general consensus is; Andrews EV13 for Baggers, Andrews EV27 for Softails.
Old Aug 27, 2012 | 10:43 AM
LowriderHarold
Default Info
Roadhog96 nailed it's behaviour on this post. Good information. I also e-mailed Andrew's about compression ratio's you can use with the EV13 & the EV27 & this was the response I got. And I quote:
I recommend 9.25:1 (stock is 8.5:1) for the EV13 cam and 9.5:1 for the EV27 cam.
Thank you,
Gary Wallace
Technical Support
Andrews Products, Inc
431 Kingston Court
Mount Prospect, IL 60056
847-759-0190
847-759-0848 Fax
gwallace@andrewsproducts.com
www.andrewsproducts.com
Would love to hear from rider's who have used these compression ratio's, with these cam's. My only concern, with these compression's, and as crappy as gas is today, I don't wan't to be hauling a bottle of octane booster around in my saddlebag's. Sorry for the hijack of this thread. Just trying to get info put out here to aid in your choice, mine, and whoever, shovelhead FXEF. End of hijack.
Ride safe,
Harold
Old Aug 27, 2012 | 12:31 PM
Schex's Avatar
Schex
Correct, it's better to go with slightly less compression and be able to put the timing to it and leaner jetting, rather than lower timing and richer just to combat detonation. IMO
Old Aug 27, 2012 | 03:24 PM
Nostalgia_93's Avatar
Nostalgia_93
On my Softail Nostalgia (1993), I've the EV-13, Mikuni, K&N air filter, high perf Crane roller tappets and the bike gained A LOT of low and mid raw power, comparing it with stock cam. It has stock compression.
When riding in group, I usually cruise at 80/90 mph, and the bike hasn't any trouble getting faster in a hurry if needed (although I like that speed range).
I have the cam from last January. The article Roadhog96 wrote was among the ones I readed, wich made me choose it instead of other options, works like he states.
If I hadn't it, would install the EV-13 again in a heartbeat, Joe Minton did a great job designing it!
Cheers,
