Halogen Bulb's
Old Aug 29, 2012 | 11:45 AM
LowriderHarold's Avatar
LowriderHarold
Default Halogen Bulb's
Changed my stock halogen headlamp bulb to an aftermarket 80/100. I know these bulbs get hotter, but that's not a issue. I also changed out all the 1157 bulb's in turn signals & tail-light, for a total of 5, to Halogen 1157 bulb's. Thing is , when I brake, or turn signal's on, headlight dim's, noticeably. I'm not very good with a volt-meter, but I do have one. If some one could instruct me on how to check my current drain, & what it is suppose to be, I sure would appreciate it. Doesn't drain my battery, but I worry what it may be doing to my electrical system, over a period of time. My stator crapped out, last year on a run to the coast, so that's all new. I do have a HD manual for the bike.
Thank's in advance for any help. Ride Safe,
Harold
Old Aug 29, 2012 | 01:18 PM
Dr.Hess's Avatar
Dr.Hess
How many Watts are those halogen 1157's? And I dunno about running an 80 watt headlight. Stock is 55. That's half again more current in the new one on a circuit the is probably barely sized for the 55 watts, plus all the connections inbetween that can get dirty.
Old Aug 29, 2012 | 04:17 PM
Spanners39's Avatar
Spanners39
You are asking too much of your system mate....
Old Aug 29, 2012 | 04:42 PM
LowriderHarold
Default Halogen
Kinda what I was afraid of. I do like the illumination the 80/100 put's out. (80w dim & 100w brite.) ( Pisses off oncoming traffic on the interstate at nite.) I'll go back to stock, & change the bulb's out. Still have the old one's. I'f I were to go to a higher amp stator, rotor, set up, say 38 amp, would that handle it? Not gonna change it , now, too much coin & trouble, but when it need's changing again. Thank's for the info.
Ride Safe,
Harold
Old Aug 29, 2012 | 04:55 PM
LowriderHarold
Default 12-volt 50/15 watt
http://www.jpcycles.com/product/3800457 Per J & P Cycles.
Ride Safe,
Harold
Old Aug 29, 2012 | 07:32 PM
Dr.Hess's Avatar
Dr.Hess
Ride Safe,
Harold
JP sez:
• Replaces stock 1157 bulbs
• 12-volt 50/15 watt
Doode, that's like 1 normal headlight at each bulb when it's on. Yeah, I guess your headlight would dim A BIT.
Old Aug 30, 2012 | 08:44 AM
grbrown's Avatar
grbrown
Too much power draw through those poor thin wires! You could install a relay, using your existing wiring to switch it, with additional thicker wires providing power to the bulb direct from the battery, which will get around the headlight problem.
Old Aug 30, 2012 | 09:30 AM
rivercityslim's Avatar
rivercityslim
If you need more light, an HID system is the way to go. Way brighter and better dispersal than any halogen, but draws less current than the stock bulb. I got mine through Motorcycle Metal, but there are several different places you can get one.
The initial cost is high compared to halogen bulbs, but believe me, the results really are like night and day. I congratulate myself on being smart enough to get one every time I ride at night.
Old Aug 30, 2012 | 09:47 AM
LowriderHarold
Smile
Thank's Graham , already changed out bulb's. Will look into upgrading charging system when it need's it. Love the extra illumination. Coming home, at night from work, lot's of critter's running across the road. Real bad when deer season is open. On another note, was stationed in the UK, early 80's at a RAF base called Bentwater's, close to Ipswich. Use to catch the ferry at Felixstowe over to Belgium & then a train to Amsterdam & get crazy! Got to see most of Europe by train. Fun days.
Ride safe,
Harold
Old Aug 30, 2012 | 09:51 AM
LowriderHarold
Thumbs up
Will check into this, slim. Thank's for the heads up. Ride Safe,
Harold
