Radio cut-out problem
Old Oct 2, 2012 | 08:22 AM
rpmerc86's Avatar
rpmerc86
Default Radio cut-out problem
I have a 1995 Ultra Classic. When the radios on and the bike is at low idle (1500rpm or less), if i activate brakes front or rear a loud pop sound is heard, the radio momentarily cuts out, then comes back on and all the lights dim. This only happens at low idle. At highway speeds there is no problem and everything works fine. It has a new battery, and stator and volt reg has been checked at dealer. I removed the cb power fuse located behind the left side panel and the cut out stopped, however the lights still dim and now the rear speakers are deactivated. Any advice would be appreciated, THX
Old Oct 2, 2012 | 09:32 AM
miacycles's Avatar
miacycles
Do a search, there is another thread on this already on the forum somewhere.
John
Old Oct 2, 2012 | 09:46 AM
jokenroll's Avatar
jokenroll
Mine does it on highway speeds, if there is too much lighting. Sounds like wiring/ ignition switch problem: just cannot deliver that much current. Thus it's not the battery or alternator, it's the stuff in between I think. Gonna thoroughly investigate during winter.
Old Oct 2, 2012 | 12:24 PM
richard567's Avatar
richard567
check your starter relay...
Old Oct 2, 2012 | 03:14 PM
jokenroll's Avatar
jokenroll
I did check mine - it's alright. I don't think it's the issue if the ignition cuts off too (loud pop for rpmerc86, and my engine dies as well). Most likely it's the ignition switch.
BigCountry1224
Sep 27, 2018 09:18 PM
WNMORE
2014-2024 Touring Models
11
Nov 6, 2017 05:22 PM
speedyr7
Aug 27, 2012 07:28 PM
Mike07FLHTC
Apr 1, 2010 06:36 PM
Stoked
Jun 25, 2005 01:07 PM
