Best engine gaskets?
Old Oct 18, 2012 | 04:53 PM
falconbrother's Avatar
falconbrother
Default Best engine gaskets?
I'm getting my gaskets together to replace my base gaskets this winter. But, as I was collecting I ended up with several options. I'm looking for input as to which one's are best.
Cylinder base gaskets: My choices are, stock paper(ish), Cometic .20 copper, steel. To be honest the steel one's look the best. But, people seem to like the Cometic coppers. The HD stock paper gaskets don't look like much.
Cylinder head gaskets: Stock HD, teflon or graphite. All of these look good. Why teflon?
Any experience to help me decide appreciated.
Old Oct 18, 2012 | 05:49 PM
HarleyReece's Avatar
HarleyReece
Your gonna get plenty of replies endorsing both cometic and genuine James. I think if you go with either you'll be good. I bought the complete cometic kit, but have yet to get it done. Waiting for colder temps an more funds to bore jugs and take heads to the machine shop.
Old Oct 18, 2012 | 06:21 PM
Tee&Vee's Avatar
Tee&Vee
Literally just finished my install. I used James because the whole kit was 100 bucks. Kinda pricey but they worked for me.
Old Oct 18, 2012 | 06:38 PM
Spanners39's Avatar
Spanners39
James is what both my Indy and my local Dealership sells....never had a problem with them.
You can get all fancy with head gaskets but on a road bike James is fine, some people like the bragging rights of hi-tech stuff but why bother when the ordinary stuff works just fine.
Old Oct 18, 2012 | 07:55 PM
1997bagger's Avatar
1997bagger
Used James and Cometics with no probs but not a better oil seal than a HD oil seal expecially in the trans area.
Old Oct 18, 2012 | 10:10 PM
IronWright's Avatar
IronWright
Old Oct 18, 2012 | 10:29 PM
brainless fxst's Avatar
brainless fxst
Don't care much for James blew two head gaskets with there junk and torque methods use stock gaskets and Harley torque methods. For a stock motor .
Old Oct 18, 2012 | 10:34 PM
blackbear's Avatar
blackbear
I used genuine james gaskets when I did the top end on my bike and they worked great.I also had my gasket surfaces on the heads and cylinders machined to help them seal better.
Old Oct 19, 2012 | 03:03 AM
GraemeR's Avatar
GraemeR
James all the way!
Old Oct 19, 2012 | 09:36 AM
Uncle Larry's Avatar
Uncle Larry
I'm presuming that you're wrenching on an EVO ... The base gaskets are one of the weak spots ... most EVO's will develop a base gasket leak ... and there are a thousand different opinions as to why they do leak ... However, once your repair is complete ( no matter which manufacturer of gaskets you decide on ) do yourself and your scooter a favor ... always let it warm up before you take off ... one of the most common denominators in base gasket leakage with the EVO is not letting some "heat build in the kitchen" .... just my.02 cents worth. Good Luck Brother!
