Dim Odometer Help
Old Nov 19, 2012 | 03:08 PM
reservoir dog's Avatar
reservoir dog
Default Dim Odometer Help
The odometer /tripmeter display on my 1997 flstc is very dim or non-existant . It does work, when you can see it . The speedo works fine , just a pain not having a fuel gauge or tripmeter for mileage . What year speedos will fit if I change it out or can it be repaired . Thanks for any help.
Old Nov 19, 2012 | 05:13 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I have the same problem with mine and I suspect it is a bad ground.
The manual says it is non repairable but some one here says they are.
I haven't messed with mine yet but I would suggest before you spend any money check your ground coming off the speedo and use dielectric grease.
If it works you have just saved yourself some money.
Old Nov 19, 2012 | 08:35 PM
EVOrider's Avatar
EVOrider
Back when I was converting my Ultra to the electronic speedometer....I got to become pretty familiar with the speedometers.
On your 1997....you can install a 1995-2003 speedometer. If you want to install a 2000-2003, you will need a retrofit kit. However, I helped a friend wire in a 2002 speedometer into a 1998 Fatboy....only with a little soldering plus the connector and a wiring diagram of both models.
The 1995-1999 electronic speedometers were pretty weak. They also liked to bleed and were dim. They were greatly improved in 2000.
Old Nov 19, 2012 | 09:01 PM
reservoir dog
Thanks ,that is some good info, now i at least know what will interchange and the best year speedo to look for . I am gonna check connections and grounds before I do anything, thanks again .
Old Nov 19, 2012 | 09:06 PM
soft 02's Avatar
soft 02
Might need to wipe off your bulb. Those things can get dusty.
Fine09
Jul 26, 2017 10:03 AM
jreichart
Dec 24, 2012 08:42 PM
bsljacques
Jun 13, 2012 07:53 PM
Scott FXSTI
Electrical/Lighting/Alarm
Jun 9, 2011 11:21 PM
becket
Feb 6, 2008 07:31 PM
