Wniter Project
Old Nov 20, 2012 | 07:22 PM
RidemyEVO's Avatar
RidemyEVO
Originally Posted by 1997bagger
Is that the HQ-24? Headquarters has been around for a while and a good name, cam has a 36 intake closing so it is a compression builder but some different numbers with duration, how far (rpm"s) does it go before falling off?
Yes it id from Doug Coffey at Head Quarters in Sombro Ontario. It doesn't really seem to want to fall off but the get up and go is around 3k , I'm been on the rear wheel of a few twinkie's doing a hard pass, if I had a horn I'd be beep beeping them out of the way.
I'm not much on the technical stuff on it but I'm pretty sure you can get the specifics from the site http://www.head-quarters.com/ . I know he's building a couple great bikes at the moment.
Old Nov 21, 2012 | 06:06 AM
Scudda's Avatar
Scudda
Originally Posted by RidemyEVO
Nothing to doing a cam job, get yourself some andrews quick install pushrods and snip out the old,then follow the instruction here, http://www.nightrider.com/biketech/hdcaminstall00.htm
Thanks for the Link. I think the only thing that makes em a little weary on doing this is the adjustable push rod adjustment....... Everything else looks pretty straight forward
Scudda's Avatar
Scudda
I don't have an ev27, I have a Headquarters rumble stick and mine kicks in at about 2800-3000 rpm. Any cam is going to give you more giddy up.
I'll check them out and see what they have
Old Nov 21, 2012 | 06:15 AM
Scudda's Avatar
Scudda
This looks like an interesting kit
http://www.head-quarters.com/html/system_75.html
However I would love to do the System 85 kit
Old Nov 21, 2012 | 03:32 PM
RidemyEVO's Avatar
RidemyEVO
Doug is a pro to deal with.
Old Nov 22, 2012 | 05:47 PM
tworinger's Avatar
tworinger
1st Gear
if you decide on the andrews I have done quite a few in stock evo's and shovels(not the 27) the 27 will make an improvement but it will really wake up with some head work later on down the road I've been prety impressed with theese after head work,and a good exhaughst,the opening and closing rates are geared towards lower compresion engines and they run cooler temps
Old Nov 23, 2012 | 04:10 AM
Scudda's Avatar
Scudda
Which ones have you used and how was the performance after the install?
2deuceguy
Blowers/Turbos/Nitrous Oxide
Jun 29, 2013 09:59 AM
jsbridgew
EVO
Mar 24, 2013 09:33 PM
leohd
Aug 15, 2012 08:27 PM
blksoftail
Exhaust System Topics
Jul 15, 2011 11:30 AM
Fearlessleader
26
Jul 1, 2008 12:05 AM
