Tear down....Here we go!
Old Jan 2, 2013 | 11:11 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by traildog
Should I drain the engine oil before I remove the cylinders? Or will all of the oil stay in the bottom of the engine?
You should drain the engine oil simply because you will want new oil in Bertha when you break in the new cylinders.
Old Jan 2, 2013 | 11:15 AM
traildog's Avatar
traildog
Originally Posted by texashillcountry
you should drain the engine oil simply because you will want new oil in bertha when you break in the new cylinders.
10/4 will do......
Old Jan 2, 2013 | 11:17 AM
traildog's Avatar
traildog
NOW, ANY RECCOMENDATIONS ON THE TYPE OF OIL TO USE?
No, STOP! I was JUST KIDDING!!!!!!!
Old Jan 2, 2013 | 12:08 PM
texashillcountry
Dirt don't hurt
:icon_banhi m:
Old Jan 2, 2013 | 12:14 PM
traildog's Avatar
traildog
I'm banning MYSELF for that slip of the tongue...............
Old Jan 2, 2013 | 02:07 PM
texashillcountry
Dirt don't hurt
Wouldn't that be a slip of the keyboard???
On a serious note every one I have ever spoke to told me to run dino oil during the break in period.
Just sayin'
Old Jan 2, 2013 | 02:13 PM
traildog's Avatar
traildog
HOW DARE YOU MENTION DINO OIL!
That's all Im running in her until she goes kablewy!
Just ordered the Hayden oil fix and the rest of the Cometic gaskets/seals.
Now to take the cylinders and heads to the machine shop I found.........
Old Jan 2, 2013 | 02:19 PM
texashillcountry
Dirt don't hurt
The way I understand it is that synthetic is so slippery that it prevents proper break in.
Where are the rest of the pics from the tear-down???
Old Jan 2, 2013 | 04:59 PM
Tom84FXST's Avatar
Tom84FXST
Taking her apart to this point was a piece of cake!
Please evaluate this view of the valve. It looks toasted to me.
It looks like she's been running quite rich to me.
The valve looks like the motor was using a little oil..but not a lot...can't tell much about valves with out complete dis-assembly to view the seat...or a compression and or leak down test.
As far as "reading" the plugs...with this unleaded, alcohol diluted crap they sell us as gas...if you are running enough fuel for the thing to run right, the plugs will be somewhat black when you pull them from a running motor. If it is running good and you are seeing no black smoke...you are probably OK...if you want it jetted perfectly...go stick it on a dyno.
Old Jan 2, 2013 | 05:41 PM
traildog's Avatar
traildog
