DAM**T Ring compressor!
Old Jan 13, 2013 | 12:57 PM
Spanners39's Avatar
Spanners39
I use a big-*** hose clamp and fit jugs with the pistons already on the rods.
Old Jan 16, 2013 | 03:31 PM
machinehed's Avatar
machinehed
Default Hose clamp.
Originally Posted by Captain Itch
Before me and my buddies had tools we used a hose clamp many times to compress rings..Make damn sure the wrist pin clips are in properly..
Ditto Captain Itch ., a large hose clamp will do the job as well as an expensive ring compressor . Be sure to locate the hose clamp adjuster screw at any point where the rings are solid and not at a gap in the rings . Tighten it just enough to let the rings slide in the barrel .
Also... be sure the piston ring grooves are clean , ensure you install and gap the rings on the piston according to specs.
Be careful , the rings are very hard and break easily !
Old Jan 17, 2013 | 09:51 PM
jsbridgew's Avatar
jsbridgew
what some have said....
pr compressors are useless IMO... i simply do it the way Dan89 and bluharley do it
however, i would very much recommend a proper wrist pin clip tool....george's sells a nice one... it's what i use
Old Jan 18, 2013 | 12:24 AM
stevequad's Avatar
stevequad
I use Teflon buttons instead of clips. Never had a failure, and you would laugh at how simple it is to install. Got them from Axtell.
Old Jan 18, 2013 | 09:31 AM
traildog's Avatar
traildog
I used a $10 ring compressor from OReillys.
KDUBYA
Engine Mechanical Topics
Apr 20, 2014 10:21 AM
threadstopper
Feb 7, 2013 05:22 PM
atrain68
Feb 26, 2011 08:09 AM
sullylang
Ironhead
Jun 17, 2008 08:58 PM
2005UltraNC
May 24, 2007 12:26 AM
