Plastic gaskets?
Old Jan 27, 2013 | 03:39 PM
traildog's Avatar
traildog
Default Plastic gaskets?
I'm installing the breather kit and I see that the gaskets that come with the kit are plastic washers? These bolt up against the jugs!?
I'm thinking I should whip out the cork roll and make new ones.
What do you all think?
Old Jan 27, 2013 | 03:44 PM
chuck3049's Avatar
chuck3049
Would help if you post some pics.
Old Jan 27, 2013 | 03:48 PM
traildog's Avatar
traildog
There ye be!
Old Jan 27, 2013 | 03:52 PM
chuck3049's Avatar
chuck3049
Looks like they will be fine, look about the same type of gasket that goes on my oil pump to the case.
Old Jan 27, 2013 | 04:29 PM
falconbrother's Avatar
falconbrother
I'll bet they are a composite and will do just fine.
Old Jan 27, 2013 | 04:34 PM
Doug S's Avatar
Doug S
They will most likely be fine, not like there's alot of preasure on that system. If you have an issue later then make a set but cork that thin may not be the best choice. Mine have been falling apart so I made new ones this year out of carboard material, has to be similar thickness. I believe one side of mine fell apart and I ran without gaskets for a year or two, no leakage.
Ds
Old Jan 27, 2013 | 05:46 PM
Tom84FXST's Avatar
Tom84FXST
Those will be fine, actually better than cork...most newer cars have their whole intake manifold made of plastic.
Old Jan 27, 2013 | 05:52 PM
bluharley's Avatar
bluharley
Originally Posted by Tom84FXST
whole intake manifold .
That's all I saw while looking at the avatar....such beauty!
SavageChopper
Engine Mechanical Topics
Jan 8, 2019 01:59 PM
mysturgis
EVO
Dec 26, 2016 06:33 PM
buffettphan
Sep 4, 2016 10:01 AM
Frédéric CM
Mar 14, 2016 04:13 PM
lockingnut
Jul 26, 2010 09:09 PM
