No Mo EFI
Old Feb 27, 2013 | 05:42 PM
Moog Player's Avatar
Moog Player
If you can't locate a harness, you will need some Deutsch pins and sockets, a few ring terminals, a Deutsch 2 position shell, a black and a grey 8 position shell, wire and some tubing to put it in. You can then make a harness per the drawings in the manual. Easy, peasy.
Old Feb 27, 2013 | 08:31 PM
Beemervet's Avatar
Beemervet
Default Harness
OK, thanks.
Old Mar 11, 2013 | 10:04 PM
Moog Player
The timer doesn't need to be changed. The rotor does. The cruise arm on later carbs will not work on earlier bikes but is an easy swap. When you remove the ECU and bracket, the mounts for the ign module are there. When you do the job with a tank swap also, it is an easy half day job. Pinwells is a good source of the wiring harness. Any flh same year carb harness will work.
Old Mar 11, 2013 | 10:20 PM
Moog Player
Here is a link to a post where i photographed all the oarts for an hsr42 swap. You can see the wire harness very well to use as a patern to homebrew yours.
https://www.hdforums.com/forum/evo-c...ml#post9184313
Old Mar 11, 2013 | 10:24 PM
Beemervet's Avatar
Beemervet
Default Harness
I just missed a harness tonight. I'm going to look for one for a little while longer.
Old Apr 27, 2013 | 03:15 PM
Beemervet's Avatar
Beemervet
Stripped everything off of the bike today, won't start putting it back together until this week sometime. First question, do I need the VOES? I guess that is what one of the connectors is for, but my manifold doesn't take one. More later probably.
Old Apr 27, 2013 | 03:40 PM
Jasper86's Avatar
Jasper86
Voes goes to a nipple on the carb, not the manifold (although one on the manifold would be a lot easier in my opinion). It is recommended, doesn't rob power and adds a margin of safety against detonation/pinging.
Old Apr 27, 2013 | 04:47 PM
Proud Marine Dad's Avatar
Proud Marine Dad
Just did this conversion over the winter. Went with the Mikuni though.You will not be disappointed. Try calling Chicago HD and see if they can find your carb harness, It seems as if the dealers are working off different computer systems, Called my local HD dealer and got "that part is discontinued". Called Chicago HD, tip from a forum member, and got "that part is discontinued but let me check the locator". There were 4 of them at dealers in the US and they even gave me the phone number. Called the dealer in Maryland and they had it and shipped it out that day, $69 for the carb wire harness for my bike plus shipping. Made it simple plug and play. You will want to find a VOES. Been told that your bike will not idle well without it. I had installed one from the get go so I can't say if that is true or not but it does idle well. Good luck.
Old Apr 27, 2013 | 04:52 PM
Beemervet's Avatar
Beemervet
I found one on ebay finally. Lookin' forward to the day............ I'm already behind on my 12-16K.
Old Apr 27, 2013 | 11:29 PM
Beemervet's Avatar
Beemervet
VOES plus fittings, harness, and hoses ordered.
