Those plugs look a whole lot better than the last set you posted, does the one on the right have a crack in the porcelian?? Looks like it in the pic. Compression is right where is should be...good job...
Ds
Dang, i didn't even notice the " crack". I just pulled them and sure enough, one is cracked on both sides. Dam, how does THAT happen? They are NEW.
No idea how it got cracked, maybe you tilted the socket when loosening...who knows...What number autolites are they, I use the coppers and they seem to last forever for me. You are running the engine in cold weather, cold air is dense with O2 so you will be running a little lean this time of year. If it's running ok then leave stuff alone until the summer/normal riding season.
