CVP Carb tune/rebuild kit and Pingel Petcock install
What is a good way to adjust the float in the carb?
What is a good way to clean out the mixture circuit, compressed air?
Part of the ignition sensor in the gear case cone melted after my ride on Tuesday where we were blasting down the road for hours at 60+. I was feeling a little hot on my thighs, but I guess the bike was getting pretty warm. Any suggestions on a good replacement for the ignition system?
Adjusting the float in the carb involves setting it on a flat, level surface on the manifold side so that the float is hanging straight down, Next, tilt the carb to 15 - 20 degrees and then measure from the gasket surface of the float bowl to the outside (bottom) edge of the float. Reading should be 10.5 - 11.5 mm. If not, bend the tab on the float and repeat. I have a piece of thin paperboard that I cut at this angle which I keep in my carb tuning box just for this purpose.
I use my scuba tanks to blow out everything when rebuilding carbs. 3000 psi. Just don't try to use canned air made for blowing out computer keyboards. You need more air pressure than that.
A nose cone is a terrible place to put electronics. All the fancy units that have the dip switches, dials, etc. for adjusting the curve on the pickup seem to fail fairly regularly because it's just too hot in the cone. You're better off using a standard pickup and then if you want to use a programmable, get one with a separate box that goes under the tank, seat, etc. like the Dyna 2000 or similar.
Thanks for the info. I slapped on the stock pipes yesterday and didn't notice any leaking today, we'll see how it does over the next few days. I've got an air compressor, so I'll pull the carb this weekend and adjust the float and blow it out again.
Looking at the dyna 2000 ignition, I think I already have that type of ignition. I have a screaming eagle ignition module on my frame, as well as an ignition coil. The dyna website talks about plugging into the existing pickup harness, so I suppose that is what I melted part of. Guess I just need to get another stock pickup and probably have the timing re-done.
Any thoughts on this anyone? I still have not adjusted the float bowl, think that would help?
