Radio options for my FLHTC?
Old Mar 26, 2013 | 08:29 AM
  #31
rivercityslim's Avatar
rivercityslim
Originally Posted by Dr.Hess
I previously replaced all the little bulbs like the fender tips and tour pack with LED's.
Originally Posted by Schex3x
I also have all led except turn signals and dash lights. Really made a difference.
Were these 'plug and play'? Where did you get them? Most of the LED kits I've seen for Harley specify late model bikes only.
Old Mar 26, 2013 | 01:03 PM
  #32
Schex's Avatar
Schex
I got these from Autozone, plugs right in, there's probably better out there for a better price, but so for no problems.
That's 8 lights just on the rear,
volt gauge does not drop anymore when useing brakes, three 1157's had more draw than I thought.
Even the small fender tips and tour pack lights drew more than I thought, forgot how much it was when I was checking everything out, but was significant amount.
The 1157 led are mostly directional, and don't really light up the license plate through the clear part of the lense like a regular bulb, I just keep one old bulb on the bike, just in case some leo gives me grief about it.
The lights look amber in the picture, but are really nice and bright red.
Attached Thumbnails Radio options for my FLHTC?-img_1002-copy.jpg   Radio options for my FLHTC?-img_1004-copy.jpg
Old Mar 28, 2013 | 10:57 AM
  #33
rivercityslim
Went a bit manic today and bought one of those Alpine KTP 445U amps as well.
Hey Doc, any chance on getting a blow-by-blow of the install and maybe even some pics?
Old Mar 28, 2013 | 01:08 PM
  #34
Dr.Hess's Avatar
Dr.Hess
Yeah, I'll see what I can do. It is just a bit larger than the last Alpine amp I had, the 18 Watt/channel one. That one I had double stickum taped to the inside of the fairing for >10 years. I'll probably do the same with this one. It came in today. Nice looking unit. The 4 channels are bridgeable to 2. Not sure I need 90 watts/channel, or that my speakers could handle that, but cool anyway.
Old Apr 13, 2014 | 09:32 PM
  #35
Renegadebig's Avatar
Renegadebig
1st Gear
can anyone help me with the factory wires on the radio? I need the colors for power, ground, constant and switch. I know the speaker wires. Any help is appreciated.
Thanks!
Old Apr 14, 2014 | 10:36 AM
  #36
Dr.Hess's Avatar
Dr.Hess
I _Think_ the red one should be constant and the yellow should be switched. I didn't trace it out, but I think the black is ground. Check with your meter.
Old Apr 14, 2014 | 10:39 AM
  #37
Fozzy4325's Avatar
Fozzy4325
Originally Posted by watindes
Hello all,
My radio has been dead since i got my 1986 FLHTC, I am looking for a good option (as cheap as possible) to restore some tunes to my ride! I am not afraid to tear into the wiring if some splicing is required (I have diagrams somewhere....) but a plug and play connector would be great or even (gasp!) an original factory radio! I know people want millions of dollars for the factory set-up and the radio is too old for the manufacturer to fix it.
Looking for opinions.....
Jesse
Biketronics has a sony solution for the bike. I had this for my 88 FLHTC. Its good. but the speakers are pooooo because of the size.
Old Apr 14, 2014 | 11:08 AM
  #38
Fozzy4325's Avatar
Fozzy4325
Thanks!
go to Ronnies microfiche you can findout all the parts , numbers and electrical diagrams
Old Nov 19, 2014 | 12:22 PM
  #39
richard567's Avatar
richard567
I put a 30 dollar pyle in mine...200watts, works great!
Old Nov 19, 2014 | 12:33 PM
  #40
Dr.Hess's Avatar
Dr.Hess
Keep in mind that "200 Watts" is really: 200/4 channels = 50 Watts PEP, * 0.707 =35 Watts (maybe) RMS per channel and that 35 Watts is at some distortion figure (THD) like 3% that would make your ears bleed. To find a closer value for the total wattage of the radio, look at the fuse in the main power (switched) lead. A 5 amp fuse will only allow 60-ish watts of power through to the radio.
As long as it sounds good to you and you like it. $30 is pretty cheap. I've had good (relatively) and not-so-good results with $30 radios in cars. I now just stick a $100 Alpine in them.
Gone Blue
EVO
14
Mar 25, 2018 02:10 PM
bigrobtemp
Audio Systems
May 27, 2017 08:46 AM
mglax13
Jan 23, 2012 12:39 PM
ENG5INE
Jun 14, 2011 09:28 PM
08 FLHT
Nov 29, 2007 08:49 PM
