Bagger Belt Drive
Old Sep 1, 2013 | 08:13 AM
  #31
miacycles's Avatar
miacycles
All belt drives have some noise as they aren't covered with a primary. They are reasonable compared to BDL, etc. To get the latest prices go to Jireh they sell the Ultima 2" belt drive for the baggers and FXR along with other styles. I like it because you can still use the floorboards.
John
Old Sep 1, 2013 | 10:18 AM
  #32
brad75raiders's Avatar
brad75raiders
I am looking at the one that hides inside the factory primary case but dont know if they can take the power of the 127' ??
Old Sep 1, 2013 | 11:10 AM
  #33
miacycles's Avatar
miacycles
You shouldn't have a problem with a good belt. The narrower belts used to be a problem, but not so much any more. You just need to ensure you have enough ventilation for cooling. Ours is a 2" belt and it handles 142 hp, 154 trq.
John
Old Sep 1, 2013 | 12:23 PM
  #34
Beemervet's Avatar
Beemervet
hmmm....... I have the same oil cooler but my lines are run differently.
Old Sep 26, 2013 | 09:48 AM
  #35
carlos1's Avatar
carlos1
2nd Gear
Hello John. Maybe i put a Ultima 3.35 open belt on my 89 fxstc. Here in Norway they say Ultima is not very good??
Please tell me about Ultima,and do the Ultima come with clutsh and outher bearings?
All you can tell me,i will be glad for
I drive around 3-5000Km year.
I could not see ut picks,was not allowed
Old Sep 26, 2013 | 02:28 PM
  #36
miacycles's Avatar
miacycles
Carlos, We've had no problems with any of their belt drives. They have street and drag style belt drives. The drag style has the outboard bearing Unfortunately they only list fitting 1900-2006.
John
Old Sep 26, 2013 | 06:58 PM
  #37
traildog's Avatar
traildog
John
OK John, I wanna see the 1900 with the open belt drive..............
Old Sep 27, 2013 | 08:27 AM
  #38
miacycles's Avatar
miacycles
It would look similar to mine just with a wider belt. Go to either midwest or ultima's web site, they have pictures and info there.
John
Old Apr 13, 2014 | 11:22 AM
  #39
brad75raiders
Is the belt drive still hanging in there? I keep eating starter gears and my jackshaft has come loose x2. With the belt drive all you have to do is pull the starter gear cover off and tighten.
what ignition are you runnng? Ever get any starter kickback? Unless I hold down my comp release down it is a kick back fest.
Old Apr 13, 2014 | 11:58 AM
  #40
Tom84FXST's Avatar
Tom84FXST
The 1903 had an open belt drive from the factory
