stock carb?
Old Apr 18, 2013 | 06:19 PM
Trmeans87's Avatar
Trmeans87
Default stock carb?
is the stock carb on a 1999 evo really that bad? im not really carb savy. maybe some one could shed some light on the stock carb or anything i can do to make it better.
Old Apr 18, 2013 | 07:56 PM
Schex's Avatar
Schex
This should keep you busy, nothing wrong with a cv carb
http://www.google.com/#hl=en&gs_rn=9...iw=583&bih=370
Old Apr 18, 2013 | 08:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Did someone say the carb was bad?
Old Apr 18, 2013 | 08:21 PM
bluharley's Avatar
bluharley
A lot of guys rip out the EFI and convert to a CV carb. That says a lot.
Old Apr 19, 2013 | 12:40 AM
GraemeR's Avatar
GraemeR
They are good up to about 100Hp! And are basically neck and neck with the Mikuni HSR 42 units until about 6000rpm and then drop off a little.
Old Apr 19, 2013 | 04:36 AM
grbrown's Avatar
grbrown
Tell us your story! What about your carb prompts you to ask your question?
Old Apr 19, 2013 | 11:26 AM
mrlexus's Avatar
mrlexus
HA! That's a tall tale. The Mikuni will produce more power at any RPM, with better throttle response to boot, and just as good fuel mileage.
CV is a good carb, and they work just fine. (but it ain't no HSR42....)
Old Apr 19, 2013 | 11:30 AM
grbrown's Avatar
grbrown
Exclamation
You're hijacking this thread! No argument that the Mikuni is a fine carb, but the OP doesn't need one, he just needs to sort out his current carb. If he can't sort that out he won't be able to sort out a new Mikuni.
Until the OP replies to the comments to date, we are unable to progress this.
Old Apr 19, 2013 | 04:02 PM
jsbridgew's Avatar
jsbridgew
CV carb is a great carb... just needs a little modding and it will perform wonderfully
Old Apr 19, 2013 | 04:38 PM
Uncle G.'s Avatar
Uncle G.
I call bullshit on your last claim. I've run them both on the same bike, and I'll give you throttle response and maybe power (haven't dynoed either setup), but no way in hell can the Mikuni match the fuel economy of the CV carb. When I had the CV carb I AVERAGED 50 MPG under nearly any conditions. The only way the Mikuni will see 50 MPG is downhill, with a tailwind. When I put the Mikuni on my fuel economy dropped from 50 down to 40-42 MPG. Even putting the "mileage kit" in the HSR42 only improved it to 45 MPG under ideal conditions.
