stock carb?
Old Apr 21, 2013 | 06:40 PM
Trmeans87's Avatar
Trmeans87
forgot to mention that its really hard to start. choke all the way out twits the throttle a dozen times and she'll fight to come alive and stay alive. i know that sounds like alot of priming but thats what always worked before.
Old Apr 21, 2013 | 06:47 PM
monkeyballhoola's Avatar
monkeyballhoola
My bike has a SE two bbl and this thread has been very informative. The old man told me to junk the SE and get a cv with a thunder jet kit. I'm not carb savvy at all and my carb has lots of flat spots in it. Low end and if I hammer on it to pass. Kinda scary when you don't know what to expect when you twist the throttl. Im with the op, definitely learning!
Old Apr 22, 2013 | 02:27 AM
Spanners39's Avatar
Spanners39
If its a CA bike you might wanna change the air cleaner assy too. And also check the timing, CA bikes are timed to 22deg advance and everything else to 35 degrees......look in the manual for the correct timing mark and strobe it....night and day difference!!! If I recall correctly the CA mark is 2 dots and the better mark is 1 dot. We get that here on imported bikes from the USA, If I find a CA one I re-time it.
jf7689
EVO
26
May 4, 2015 11:19 AM
VASportster
May 8, 2011 02:13 PM
JosephGarcia
Feb 18, 2008 02:59 PM
michaelbarry
Jul 18, 2007 03:19 PM
stone_rider420
Apr 14, 2007 11:03 AM
