Evo top end(first timer)
Old Apr 19, 2013 | 06:26 AM
junglejoe's Avatar
junglejoe
Default Evo top end(first timer)
https://www.hdforums.com/forum/engin...rst-timer.html
Ill post the rest of the build here in the Evo section...stay tuned!
Old Apr 20, 2013 | 09:40 PM
junglejoe's Avatar
junglejoe
Nothing much, got the cam,pushrods,..OHH, and also the METAL breather tube.
Dropped the oil pan to clean it out,actually was reallt clean.But i just wanted to make sure
Where is the best place to get the lifters for the money?
Old Apr 21, 2013 | 07:09 PM
aces&8s's Avatar
aces&8s
Im putting new stock lifters back in that will do fine for not much cash. Why, because I figure Ill change them again in 40K mi any way. Adj pushrods make that an easy do.
Old Apr 21, 2013 | 09:34 PM
junglejoe's Avatar
junglejoe
Yea, I ordered adjustable pushrods as well.I guess stock lifters is what i'm getting too.
Old Apr 22, 2013 | 05:55 PM
junglejoe's Avatar
junglejoe
Will be couple weeks befor i get the top end back from Hillside...i'll be putting the cam,and all that other chit in this weekend...
Old Apr 25, 2013 | 03:34 PM
junglejoe's Avatar
junglejoe
just pics of some of the parts..everyone likes pics...LOL The 3 things in the bag are for the pushrod blocks to make sure they are on straight. On the steel breather, I "assume" that the "T" is the timing mark??
Attached Thumbnails Evo top end(first timer)-dscn2285.jpg   Evo top end(first timer)-dscn2287.jpg   Evo top end(first timer)-dscn2288.jpg   Evo top end(first timer)-dscn2289.jpg   Evo top end(first timer)-dscn2294.jpg
Old Apr 25, 2013 | 03:49 PM
aces&8s's Avatar
aces&8s
Nice to see things come together.
Old Apr 27, 2013 | 07:24 PM
junglejoe's Avatar
junglejoe
Got the cam and steel breather tube installed today.Camshaft endplay is .010-.009 useing a .055 shim and the original thrust washer...should be good i think??
Old Apr 28, 2013 | 04:12 PM
junglejoe's Avatar
junglejoe
Anyone got any secrets to getting the piston off the rod? Or is there a tool you gotta have?
Old Apr 28, 2013 | 05:50 PM
Spanners39's Avatar
Spanners39
Wrist pin should just push through but you can use heat if it doesn't. A heat gun is best as no flame.
Stuff rags in the crankcases before flicking the piston circlip out.
