Evo top end(first timer)
Old May 2, 2013 | 08:18 PM
Spanners39's Avatar
Spanners39
Heat the pistons up, then the pins will slide in. Bake them or use a heat gun but they don't have to be smoking hot, just rather warm.
Old May 2, 2013 | 10:11 PM
terrapin88's Avatar
terrapin88
My top end is still in pieces sitting on my bench junglejoe. I found out today the rest of the parts and the flex hone are waiting for me at the post office. Didn't get home in time to grab them tonight. Looks like tomorrow I'm going to start cleaning and resembling things. I'm dying to get this done so I can get out and ride.
Old May 3, 2013 | 08:11 PM
machinehed's Avatar
machinehed
Default installing tight fitting pins.
Ditto Spanners39 as usual .
Time to break out the oven mitts.
As Spanners said , try baking the pistons in your oven @ around 300 F so they are still hot enough when you get them to where you need them. Lube the pins and procede carefully .
Another alternate way is to lube up the pins and then put them in your freezer overnight and again procede carefully.
All of this is basically to ensure that when the pin is inserted , it will travel through the hole easily and not gouge the softer piston material.
Old May 3, 2013 | 08:51 PM
terrapin88's Avatar
terrapin88
got it. Thanks for the info guys. I'll try the freezer. I'm planning on putting the pistons into the cylinders when they are upside down on my bench. Be easier for me to compress the rings with the tool I am using plus the oven is on the fritz right now. Looks like I need to add a heat gun to my toolbox.
Old May 4, 2013 | 07:59 AM
junglejoe's Avatar
junglejoe
Yeah, makes sence.I use to freeze my nitrous bottles the night before so I could get more in it, the filling station soon figured that out and put up a sign that sad" will not fill ANY bottles that has been in freezer"...LOL
Old May 4, 2013 | 08:03 AM
junglejoe's Avatar
junglejoe
OHH, should all the bolts be put back in with loc tite red or blue?
Old May 4, 2013 | 08:30 AM
terrapin88's Avatar
terrapin88
Red loctite is permanent while blue loctite will allow you to remove the bolts again when you need to.
What bolts are you talking about? I don't think the manual wants you to use loctite on any of the motor fasteners except the cylinder studs, and they need red loctite 271.
Old May 14, 2013 | 07:07 AM
junglejoe's Avatar
junglejoe
I just remembered something.....on my cam shim, and the washer...I seen some that had like a 45 cut into it.mine is just round? it was for lifter clearance....I'll try to find a pic of what I'm talking about...
Old May 14, 2013 | 12:10 PM
junglejoe's Avatar
junglejoe
forum acting weird this morning... any answer to question above?
Old May 21, 2013 | 06:36 AM
junglejoe's Avatar
junglejoe
Still waiting on the heads and everything else. . .
