Evo top end(first timer)
Old Apr 28, 2013 | 06:02 PM
terrapin88's Avatar
terrapin88
Originally Posted by junglejoe
Anyone got any secrets to getting the piston off the rod? Or is there a tool you gotta have?
I've seen tools for sale on online. One I think was $65 or so. I made one and it worked great.
I used 3/8 hex bolt 6" long, a 3/8 nut, a 7/8" ID copper pipe coupling and a flat washer wide enough to cover it. You'll need 2 9/16 deep sockets too.
The hex bolt goes thru the wrist pin and the head of the bolt is just bigger than the pin diameter so it grabs the pin and pulls it out of the rod as you tighten the nut on the end of the bolt. On the other side of the piston slide the coupling over the blot and make it fight flat against the piston. That's just large enough to fit over the pin when it comes out, and just small enough to fit flat against the piston. Slide the flat washer over the bolt and up against the coupling. Thread on the nut and use one socket to tighten it against the washer and the other socket on the bolt head so the blot doesnt spin. Gently tighten the nut till the pin slides out most of the way. Then remove the tool and wiggle it out the rest of the way, or leave it sticking out of the piston for safe keeping. It would be better is you looked up wrist pin removal tools to see how it works. Not sure if I'm good at verbalize it. Bottom line is it cost me pennies and it worked fine. Good luck.
PS- Dont forget to pull your circlips first.
Let me know if you have any questions-
Old Apr 28, 2013 | 08:43 PM
junglejoe's Avatar
junglejoe
THANKS for that tip!! Yea, i pulled the C clips off, I'll damn sure give your tool a shot!! seems like a damn good idea!
Old Apr 29, 2013 | 12:05 AM
terrapin88's Avatar
terrapin88
Glad to help man.
I forgot to remove the circlips off one of the pistons and I was wondering why the pin wasn't moving while I tightened the nut on my home made tool. lol
Old Apr 30, 2013 | 08:53 PM
junglejoe's Avatar
junglejoe
Just got done pulling the wrist pins out and the old pistons off with the tool Terrapin88 showed... Went to Ace, and bought all of it for under 4 bucks!!!!Worked like new money!! thanks man!
Old May 1, 2013 | 09:44 AM
terrapin88's Avatar
terrapin88
Awesome man! Glad I could help.
Old May 2, 2013 | 04:32 PM
machinehed's Avatar
machinehed
Default wrist pins.
Glad to hear all is going well .
My 2 cents here.
The homemade pin removal tool works great, but you must be very carefull
when reinstalling the pins with this setup as any slight misalignment will gouge the piston pin hole. Take your time and ensure the pin is going back in
correctly.
Old May 2, 2013 | 04:38 PM
terrapin88's Avatar
terrapin88
machinehed, my natural instinct is to gently tap the pin back in while supporting the rod. Would that be unwise? I plan to use my little tool, but it would be easier to tap it back in.
Old May 2, 2013 | 05:15 PM
Spanners39's Avatar
Spanners39
DON'T TAP IT!!!!!!!!! Many bad things can happen, you could gouge the rod eye or even bend the rod.
Old May 2, 2013 | 06:05 PM
terrapin88's Avatar
terrapin88
Copy that. Thanks.
Old May 2, 2013 | 06:42 PM
junglejoe's Avatar
junglejoe
I was wondering how its going to work putting it back together. If I see its not going smoothly, I got a buddy who owns a shop I'll have him come over and put it back in for me,i just wanted to do it all myself.I'm not buying the tool, because I don't plan to do this again.I like to tear stuff apart when its NOT broke or messed up, I know, weird. But I just don't have time to do it.Once I get off work all day, I don't feel like doing chit!Flooring is my thing,this gives me a headach! lol
hows yours coming terrapin..I wont get my pistons and cyl's and heads back from machine shop for another week! That's all I'm waiting on
