Evo top end(first timer)
Old Jun 12, 2013 | 01:12 PM
  #91
DravenGSX's Avatar
DravenGSX
Sounds awesome!
Old Jun 12, 2013 | 04:07 PM
  #92
Schex's Avatar
Schex
Originally Posted by junglejoe
FINALLY....here it is! I'll tell, ya, i'v got about 130 miles on it so far,I had to get in it a "little" ..It pulls like a raped ape!!!
http://youtu.be/wfrCh_BeyFE
tater ,tater, tater........good job
Old Jun 13, 2013 | 12:47 PM
  #93
terrapin88's Avatar
terrapin88
way to go Joe!
Old Jun 14, 2013 | 06:44 AM
  #94
junglejoe's Avatar
junglejoe
Thanks fellas! Changed the oil yesterday, surprisingly, it was fairly clean! It will haze that back tire at 3/4 throttle with ease!It's not the fastest 80 incher,but you better not get caught sleepin ! =) but I had a plan,stuck to it, and it worked.Usually, I start building something, get halfway through it, and change things up. So this one came out like a blueprint just exactly how I wanted it
Old Jun 15, 2013 | 07:26 AM
  #95
junglejoe's Avatar
junglejoe
Question. When I adjusted the pushrods(rev-tech ) I only went 3 1/2 turns.The lifters were never ran, new. I now seen where I shoulda went 4 turns, should I readjust them? don't here any noises, but if the valve isn't opening all the way, i'm loosing power right?
Old Jun 15, 2013 | 07:29 AM
  #96
junglejoe's Avatar
junglejoe
Oh yea, one other thing... On the front brake, when I pull the lever brake works fine and the brake light.BUT I have to manually push the lever back out just a little to get the light to go off.Then when I do that, its like it wants the spring back like i'm pulling it, not a lot, but just enough to where something isn't right
Old Jun 24, 2013 | 07:00 AM
  #97
junglejoe's Avatar
junglejoe
I'v got about 300 miles on it so far, just been swamped at work. But got a couple issues....Like if I just come off the clutch and gas it, it pulls like a freight train,if I am just cruising say like 40 mph and up and gas it, it is busting up bad! popping out of the pipes...any suggestions? I took it to my indy and he did the jet kit, so I don't know whats in it.I'll have to ask him, but it runs great until you try to crank the throttle at cruising
Old Jun 24, 2013 | 07:08 AM
  #98
gsxrboy96's Avatar
gsxrboy96
That's because you haven't sent the carb to me ! Lol you really need to open it up and see what u got, sounds like maybe the accelerator pump or something is up, it shouldn't be breaking up tho,
Old Jun 24, 2013 | 07:06 PM
  #99
junglejoe's Avatar
junglejoe
I'v just been swamped at work... I AM going to send it to you though.lol I did the timing like you told me so I dunno if timing would cause it or not. I know one thing though, It is a beast!!! And I haven't even got in it yet! At 3500 shifting into 2nd gear, it WILL pull the front tire with ease! I think I'm going to have to put some bolts or something in the end of the pipes,it's just WAAYYYY to loud and would be good for 12-15 ftlbs torque.. open 1 3/4 drag pipes on it now
Roadflyer
Engine Mechanical Topics
Feb 1, 2016 02:08 PM
Pass'n through
Feb 1, 2015 06:28 PM
flhchaz
EVO
Jan 5, 2015 07:33 PM
fxesuperglide77
Feb 15, 2012 03:06 PM
blair
Oct 15, 2011 09:43 AM
