Evo top end(first timer)
Old May 24, 2013 | 07:25 AM
  #41
Schex's Avatar
Schex
terrapin88 and junglejoe,
like to see vids when your builds are done.
(and maybe some running through the gears after breakin)
Old May 24, 2013 | 10:37 AM
  #42
DravenGSX's Avatar
DravenGSX
Subscribed! Looking forward to seeing it fire.
Old May 24, 2013 | 12:12 PM
  #43
terrapin88's Avatar
terrapin88
I'll try to accommodate you Schex3x. I'll make sure it runs before I hit record though. Unless you guys want so see me cuss and cry if it won't fire.
Good luck junglejoe.
Old May 25, 2013 | 01:08 PM
  #44
junglejoe's Avatar
junglejoe
Yea, I'll DEFINATLY get some videos ..NOW, was just out in the garage, went to put the cyl's on,WRONG GASKET KIT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!Sent me one for a twin cam!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I mean seriously!?!?!?!?!?!?!?! what a wasted F'n weekend!So now another dead GD weekend ...I know I know...calm down, but DAMN! Can I ever get a brake!!
Pics later, I need a beer and don't even drink!!F*ck
Old May 25, 2013 | 02:53 PM
  #45
junglejoe's Avatar
junglejoe
anyone know if this part number cometic gasket kit 17040-92a would work for a .020 over? That's the thing, I don't even f8ckin know what thicjness I need it to be to get to the 9.5 compression. pistons are part number K1646. I'm just trying to get it together this weekend, Ill deal with the parts guy when he opens back up Tuesday...
EDIT:::: never mind, i'll just freakin wait...just pisses me off real good!
Old Jun 1, 2013 | 06:27 AM
  #46
junglejoe's Avatar
junglejoe
FINALLY.... put the cyl's on last night when I got off work, to tired to do anything else. But HOPEFULLY it fires up later or Sunday... will upload pics later fellas. . .
Old Jun 1, 2013 | 06:48 AM
  #47
junglejoe's Avatar
junglejoe
Oh yea, couple questions...will it be ok to start it with out the carb being jetted and most importantly..ONCE I get ready to hit the button, how do I set the timing??befor I took it apart,I marked where the timing was ,but I know all that changes now.Are these things like cars, does the cam have to be broken in?I know on cars,you take a chance of whipping out a cam lobe if you start it and don't let it run for a little bit
Old Jun 1, 2013 | 09:05 AM
  #48
1997bagger's Avatar
1997bagger
Slow down Joe, vital steps ahead! get some fuel on that carb before installing it, heat and pressure is needed to seat rings but excessive heat from being lean is another teardown. List your carb and ignition and let the Evo forum do their thing.
On the cam, as long as you have lube on it during install and engine is gettin oil at startup, it will be fine. If it isn't getting oil you will know because the lifters sound like a sewing machine.
Deep Breath's and set it up from the beginning and ride when it is right
Old Jun 1, 2013 | 04:25 PM
  #49
junglejoe's Avatar
junglejoe
Thanks Bagger!Carb is the stock one, I don't know if it was jetted or not.Ignition, I assume stock but maybe not,its got a quick detach cover for easy adjustment.there is some numbers on it with a sharpie marker, but I don't know if its stock or not.it will pull to 5500 and still not hit the rev limiter befor I took it apart if that helps. Now, I just set the pushrods, NEW lifters and they have been soaking for a week, But I set them at zero lash, and went 3 1/2 turns, BUT the pushrods are not tight?? Is it because they haven't been ran? Rev tech pushrods
Old Jun 1, 2013 | 05:57 PM
  #50
junglejoe's Avatar
junglejoe
Well, I made sure each lifter was at its lowest point, set the pushrod until it still turned freely by finger, THEN went 3 1/2 turns.Waited,I could turn the pushrods again, went to rotate to engine to do the other 2 pushrods, and something doesn't feel right so I stopped.Seems the lifters are to tight,maybe i'm just in panic mode???
