cam change??
Old Apr 23, 2013 | 11:42 AM
onebad2's Avatar
onebad2
Default cam change??
Well its time for me to make my 91 fatboy run faster, Im having the heads done, reringing it and putting a ev27 cam in it. Have a few questions hopfull u guys can help me. I got a used cam from local swap, looks like new? plan to reuse stock pushrods for now(will cut some day and replace $$). the cam came with a round thrush washer and the one I took out had a funny shape stock one, shoud I reuse the stock one. It looks like the one with new cam only rides on the inner bearing. also should i buy new c clips for the pistons. I checked inner lobe clearance on the cam at case and I can fit the tip of a zip tie in so thinking im good there. thanks for and advice and help. Corey
Old Apr 23, 2013 | 03:05 PM
Spanners39's Avatar
Spanners39
If the hardening on the cam lobes is Ok then it fine to use. There was a 50 thou change to the length of the cams at some point so go to the Andrews cam website and download the installation instructions for the EV27 which will give you the advice you need regarding shims etc.
Don't be in a hurry to install adjustable pushrods....lazy people get lazy results if you ask me ;-)
Old Apr 23, 2013 | 10:49 PM
onebad2's Avatar
onebad2
I got the info from andrews, looks simple, plan to button up the engine tomorrow night. then wait for paint work to be done. figure while tanks are of might as well give it a face lift too! are the stock push rods ok to use ???. sure cant wait for it to be done and nice weather, lots of rain here now.
TXSailor
Sep 7, 2023 09:03 AM
Bikerscum
2014-2024 Touring Models
Jun 7, 2015 09:53 PM
busterman2
EVO
Nov 26, 2012 09:59 AM
redrott
EVO
Jul 8, 2010 12:01 PM
gargoyle
Exhaust System Topics
Mar 7, 2008 08:09 PM
