tuning help needed
Old May 17, 2013 | 03:37 AM
som69's Avatar
som69
Default tuning help needed
Have run out of ideas - 94 wide glide Mikuni carb single fire ignition (dyna) no electronics uses centrifugal advance unit. Bike runs fine pulls strong with no flat spots. When I come to stop it will not return to idle right away, no tack but it runs about 1500 to 1800 rpm, after stopping it will return to idle after a few seconds. Is it the carb or the advance unit?
Old May 17, 2013 | 03:38 AM
Spanners39's Avatar
Spanners39
Its most likely an intake leak. Check the seals between carby and manifold and manifold and heads.
Old May 17, 2013 | 05:03 AM
som69's Avatar
som69
Intake leak was my first thought also but could not find a leak but will check again just to be sure ...
Old May 17, 2013 | 05:20 AM
gsxrboy96's Avatar
gsxrboy96
If you can't find a leak, try fattening the bike up a little, when they're really lean, they will do the sane thing
Old May 17, 2013 | 06:20 AM
Rob85WG's Avatar
Rob85WG
Does your throttle have two cables? I think a missing closing cable will do that.
Old May 17, 2013 | 06:45 AM
som69's Avatar
som69
plugs look good engine does not burp fart or make any strange sounds runs strong - has return cable for idle and it is working right - this has me stumped for sure...
Old May 17, 2013 | 07:14 AM
1984_FXRT's Avatar
1984_FXRT
Symptoms point to a vacuum leak - but, if you're still running the centrifugal advance (why, btw???) it's not probable, but, it's possible for the weights to be hanging up and not allowing the timing to retard when the RPMs drop.
Raineman
EVO
13
Nov 19, 2013 08:43 AM
pappaswan
May 9, 2009 09:12 AM
hddave2
Mar 19, 2008 06:10 AM
greezymonkee
EVO
22
Oct 28, 2007 07:34 PM
tangellow
Exhaust System Topics
May 15, 2006 03:51 PM
