FXSTC -- New Handlebars
Old Feb 24, 2014 | 07:38 PM
  #41
HarDlife's Avatar
HarDlife
Shouldn't have to lube throttle grip. Need to take it off and see why it's sticky.
Old Feb 24, 2014 | 07:39 PM
  #42
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by crazymjb
Haven't put the grip on yet, but just so you guys know, I stuck a piece of coathanger (straight) into an electrical drill and spun it back and fourth a few times (crawled around the inside of the grip) and it loosened it right up.
Once I have it all together, I'll snap a picture.
What should I use to lube the throttle handgrip? It's VERY sticky on coming back, even with the return cable adjusted loose.
Mike
Congrats on getting off the left grip.
Don't lube the throttle grip with anything. Just clean it as best you can.
Any lube you put in there will pick up dirt and make it harder to twist.
Old Feb 24, 2014 | 07:45 PM
  #43
QC's Avatar
QC
I've changed grips a couple times now and may again cuz I'm not sold on the Avons I put on and haven't had any trouble getting the left off. You may need to hit the throttle side of your bar with some sandpaper to get the throttle to work correctly.
Old Feb 24, 2014 | 08:03 PM
  #44
Beemervet's Avatar
Beemervet
Sounds like you may need to lube the return cable, or replace it.
Old Feb 24, 2014 | 10:51 PM
  #45
crazymjb's Avatar
crazymjb
Cables are new (return snapped last fall). I think it may be the lock, I forget to check if its loosened all the way.
Mike
Old Feb 24, 2014 | 11:06 PM
  #46
Beemervet's Avatar
Beemervet
Yep, always start with the free and easy stuff!
Old Feb 26, 2014 | 09:28 AM
  #47
crazymjb's Avatar
crazymjb
They are in desperate need of a cleaning, but here they are:
The fit is literally perfect. I can't wait to really try them out.
The throttle is still a little sticky, I'll pull it apart when it's warmer.
There is also a tight bend (from previous setup) of the metal brake line, it doesn't seem to effect anything but if it does I suppose I will be upgrading the front lines to braided hose.
Mike
Old Feb 26, 2014 | 10:33 AM
  #48
Beemervet's Avatar
Beemervet
I realized several years ago that I could no longer ride with my wrists turned. Bars like that solved that problem when I built the chopper and monkey bars fixed the RG.
Old Feb 26, 2014 | 11:12 AM
  #49
crazymjb's Avatar
crazymjb
Yea I certainly don't understand how some people ride with their bikes set up as they are.
Mike
rowdyj
Jun 12, 2014 07:45 AM
ghoticov
Mar 8, 2013 04:45 AM
RonT1972
Jun 30, 2012 05:03 PM
bubba626
Apr 12, 2010 03:09 PM
Bryan53
Feb 11, 2008 01:29 PM
