wobble wobble
Old May 28, 2013 | 05:27 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Spanners39
Hiring one is worth the cost as it makes the job waaaaay easier. I'll take my bike apart anywhere if there are better facilities than in my workshop.....can't get too precious, its only a lump of metal after all....a very nice lump of metal but hey, let's be real about this
I can't agree more.
TC's are a hunk of metal. j/k
The problem with your analogy is that he has an EVO!!!!!!
Just poking fun...
Old May 28, 2013 | 06:40 PM
RidemyEVO's Avatar
RidemyEVO
Originally Posted by texashillcountry
I can't agree more.
Just poking fun...
Poke him Texas he can take it.
Old May 28, 2013 | 06:42 PM
RidemyEVO's Avatar
RidemyEVO
Thanks Bill the pictures are appreciated and scarey at the same time. Did you find that your bearings were worn out when you finally got to them?
Old May 28, 2013 | 09:55 PM
Spanners39's Avatar
Spanners39
I have to go for a colonoscopy tomorrow so no jokes about "Poking" please dudes
Its only a screening precaution as both parents have had bowel cancer so don't go worrying about me
Old May 29, 2013 | 06:58 AM
grbrown's Avatar
grbrown
To get a better understanding of bagger wobble, read my thread about it. For our Evos the things to address first are those already mentioned, but especially replace the cleve blocks! The other things that can cause handling problems are low tyre pressures, old or worn tyres, old rubber engine mountings, bad vehicle or wheel alignment, the list goes on.
Old May 29, 2013 | 03:14 PM
BungoBill's Avatar
BungoBill
Yeah. I knew they were worn out because of the shudder when I braked
or when you sit on the bike with the front brake applied you could feel the "play/wear" when you moved the h.bars back & f.ward..
Also.... Luckily my old Ultra had passed 2 M.O.T (UK dept of transport yearly roadwothiness tests) without the Tester finding the bearing problem.
The steering head bearings had to be replaced its just that I didnt want to splash out any $$$ to a wrench for fixing it.
Its not a job for the average DIY guy and I wouldnt like to attempt it again. Dont know what it would cost over in the US to have the work done but I think that overe here in the UK you would be looking at the equivalent to 8/900$. Bungo.
Old Jun 1, 2013 | 06:19 PM
RidemyEVO's Avatar
RidemyEVO
Got around to checking air prssure in the front forks and found there was next to none. I added some air and front end seems better.
Old Jun 1, 2013 | 06:32 PM
Stiggy's Avatar
Stiggy
With age and lots of miles, my Road Glide doesn't want to hold air in the front shocks very well, even with new seals installed.
I did go to S/E fork fluid ( 15 wt?) and the ride is so much better that I don't even check the air anymore. Might consider it.
Old Jun 2, 2013 | 04:19 AM
grbrown's Avatar
grbrown
Originally Posted by Stiggy
With age and lots of miles, my Road Glide doen't want to hold ar in the front shocks very well, even with new seals installed.
There are several places the forks can be losing air. The valve in the bars is a tyre valve, so just replace it! I had one start leaking a few years ago. Then there is the hose between the bars and the manifold on the fork tops, plus the various seals and washers in them. Shouldn't be difficult to solve, just a bit fiddly.
Old Jun 2, 2013 | 11:03 AM
RidemyEVO's Avatar
RidemyEVO
Graham I don't think they were right out of air , I did have them filled a few years back with about 7 lbs. I have the iso grips and I was having a hard time finding a air valve pump that would reach in deep enough and as well a air checker guage that was a straight end but I'm good now. I have about 9 lbs in it and feels good. I had 15lbs but was a bit stiff but solid ride.
