3 phase charging system check?
Old Jun 21, 2013 | 12:18 PM
  #31
soft 02's Avatar
soft 02
Here is the process, hope this helps
AC Output Check:
Unplug the regulator plug from the stator
Start motorcycle and change Voltmeter to AC volts.
Probe both stator wires with your meter leads.
The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. (Reading will vary depending on system, check service manual specification)
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multi meter to Ohm x 1 scale.
Probe each stator wires with meter leads and check resistance on meter.
Resistance should be in the range of 0.1-0.5 Ohms. (Reading will vary depending on system, check service manual for specification)
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
Stator IB test or Ground Check:
Probe each stator wire with your positive lead on multi meter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Insure the regulator body is grounded or grounding wire is fastened tight to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multi meter to Diode Scale.
Place your Multi meter positive lead on each AC output wire.
Place your multi meter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multi meter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire.
The reading should be Infinite.
With your meter on the same setting, place your multi meter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multi meter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ∞
Battery charge lead AC output 2 ∞
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ∞
AC output 2 Ground ∞
Old Jun 21, 2013 | 02:00 PM
  #32
jokenroll's Avatar
jokenroll
Thanx Soft02, I did all those.. It all checks out alright. Oh well, I guess I didn't check the
ac side - ground path... I will go through them again, but it puzzles me more and more
Old Jun 21, 2013 | 02:32 PM
  #33
soft 02's Avatar
soft 02
Electricity can be funny. Hope the reg fixes it up. When mine went out it was spiking at 18v on a cycle.
Old Jun 24, 2013 | 10:28 AM
  #34
jokenroll's Avatar
jokenroll
Finally fixed! I took a chance and bought that huge CycleElectric 40A reg - works like a breeze - never had so much juice on idle! I guess it's also thanks to that $190 CycleElectric rotor (stamped with HD part # only)... I'll keep this rotor instead of that no-name sealed one.
So I guess what happened before, the original no-name reg was defective to begin with, or got fried while trying it w/o load, then the HD one I also tried w/o load first, or, maybe it was as well defective...
Nevertheless, problem solved, and, as usual, the most obvious explanation turned out to be true
Thank you for your input, gentlemen!
Fitterwelder
Electrical/Lighting/Alarm
May 16, 2019 11:52 AM
Dave Bell
Aug 10, 2016 10:20 AM
96RK
Dec 18, 2011 06:24 PM
hellboyrich
Mar 6, 2011 11:52 AM
1993FLHS
Apr 26, 2010 05:21 AM
