checking motormount
Old Jul 1, 2013 | 10:32 AM
RidemyEVO's Avatar
RidemyEVO
Default checking motormount
Hey guys I was wandering if I put a car crank jack under my engine and lift a bit and the front motor mount seperates or lifts away from its normal seated position would this indicate it is worn? Bolts are all secure.
Old Jul 1, 2013 | 11:49 AM
Bumpandrun's Avatar
Bumpandrun
Yep sounds like it needs new. Pretty easy and makes a big diff.
Old Jul 1, 2013 | 04:45 PM
miacycles's Avatar
miacycles
We've been using the Beull front motor mount, '98 I believe, same height-better material.
John
Old Jul 1, 2013 | 05:18 PM
RidemyEVO's Avatar
RidemyEVO
Thanks guys . John I think im going to order the swing arm kit from true track and I see they have a kit that includes the motor mount.
Old Jul 1, 2013 | 08:06 PM
miacycles's Avatar
miacycles
I have a true track and that mount on my bagger. I will put one on the FXR when I get around to building it.
John
Old Jul 2, 2013 | 09:28 AM
RidemyEVO's Avatar
RidemyEVO
Put the order in to true track, I sure hope the cost of it proves itself.I don't run much more than 15 - 20 kph over the speed limit here other than passing and the speed limit is generally 90 - 100 kph, will I notice a big differnce cruising at these speeds?
Old Jul 2, 2013 | 04:19 PM
miacycles's Avatar
miacycles
That would depend on how bad the originals were. Most people see an improvement.
John
BiggestDawg
Aug 23, 2010 03:10 PM
1plumr1
Oct 12, 2009 03:49 PM
Hardly Dangerous
Jul 24, 2008 01:36 PM
Brooklyn Redneck
Apr 3, 2007 12:14 PM
UNCLE SAMMY
Exhaust System Topics
Jan 7, 2007 12:43 PM
