Which year Evo to buy?
Old Jul 4, 2013 | 10:01 AM
McMurphy's Avatar
McMurphy
Default Which year Evo to buy?
Hi Guys
I finally am ready to get the bike Ive been wanting.
But want to be sure about a few things first.
Ive done the searches...read "The Sweet Years" article...but there seems to be more info out there I cant find.
Im thinking the years 1995 - 2000....under 25,000 miles. Wide Glide or Softail...not sure yet.
Ive heard about gear driven cams....base gaskets...but which years....questions like that.
I appreciate it...and hopefully will be back here with a new old ride. Moneys burning a hole in my pocket!
Thanks
Later
Old Jul 4, 2013 | 11:18 AM
fxstc1999's Avatar
fxstc1999
1999 was the last year for the EVO motor.
Old Jul 4, 2013 | 11:43 AM
Beemervet's Avatar
Beemervet
2000 FXR4 was the last Evo.
Old Jul 4, 2013 | 12:15 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by McMurphy
Hi Guys
Thanks
Later
I'd get anything between 1990 to 1995.
There were many upgrades done in 1990 and in '96 they put more electronics on them.
I prefer a more mechanical bike.
Old Jul 4, 2013 | 12:36 PM
jokenroll's Avatar
jokenroll
Agree. There is a major change on deckers also in '93 I believe: the oil tank went under the tranny.
Old Jul 4, 2013 | 12:57 PM
PoPo75's Avatar
PoPo75
True. I believe Baggers and FX's had under the tranny oil tanks Sporties and Softails remained under the seat.
I have a 1997 Electra Glide and a 1999 Softail. Both are EVO's and run great and are easy to maintain yourself if that's what you're into.
I have heard of EVO engines having issues regarding shitty cam bearings from the factory so if ever you have the motor out that would be the first thing I would change.
Other than that I like them.
Oh... one other thing my '97 Electra glide Ultra Classic (700+ lbs) and my '99 Softail (500+ lbs) have relatively the same engine. Both completely stock except for air cleaner and exhaust. I think the MoCo should have thought that one through a little bit. The Softail SEEMS like it has twice the power of the Ultra. When in reality they are probably pretty close in performance.
Old Jul 4, 2013 | 12:59 PM
1997bagger's Avatar
1997bagger
Seems like the later yeared Evo's had the bugs worked out but they ALL will need some sort of maintanace work done, no guarantee's of base gaskets not leaking unless they are replaced, inner cam bearing and lifters need to know history for peace of mind.
Any year Evo can be a great bike, prefered model needs some thought and riding style of the purchaser calculated into the choice. A Evo evolves into a extension of the owner, over time and if the right bike, it becomes personal. Don't impulse buy, ask what has been done to the engine as stock is great and you will know what needs done to it, alot of work done to a engine can be good and bad - get detailed info and beware of high compression engines if your mechanical skills are at base level.
Summing up the garble, get the best mechanical bike you can but work will still need done and apply your personality to the bike you want with some homework, The Evo section can't supply which bike model hits home and touches your soul, you will see what we are talking about when you find the right bike my friend.
Old Jul 4, 2013 | 01:46 PM
jokenroll's Avatar
jokenroll
Most eves by this point would have their cam changed anyways and the bearing along with it. Then there's no need to worry about that, unless the owner doesn't know, then the only way to tell, is to remove the cone...
Old Jul 4, 2013 | 01:48 PM
jokenroll's Avatar
jokenroll
Baggers and softails feel different because even though the engine and the tranny are identical, the primary and final ratios are different (that could be easily adjusted according to the taste).
Old Jul 4, 2013 | 02:01 PM
PoPo75's Avatar
PoPo75
Really? I will have to research that. Thanks.
