1990 fltc start up issue
Old Jul 17, 2013 | 09:52 AM
traxster's Avatar
traxster
Default 1990 fltc start up issue
I have a 90 fltc, when i hit the starter button and hold it, there will be a pause sometimes, then she fires up... my buddy has the same bike but a 89, and his fires rite away... what could be causing this and is this even an issue? thanks
Old Jul 17, 2013 | 02:02 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Sounds like the start of the dreaded click problem.
Basically corrosion builds up on all your electrical connections and makes it harder to get the voltage you need to the starter.
Time to pull out the volt meter.
Do you have one?
Old Jul 18, 2013 | 03:42 PM
traxster's Avatar
traxster
Yes but there is no click it fires then pauses then fires up and starts
Old Jul 19, 2013 | 09:36 PM
machinehed's Avatar
machinehed
Welcome., im assuming that when you say " it fires up " you mean it turns over.?
If this is so ... your dealing with switches,wiring and a starter that are 23 years old.
1) clean the switches by disconnecting the bat. and spray your choice of cleaner into each switch , cycle the switches while spraying the cleaner into them until they drain clear liquid, blow out the switches with comp. air or lung power.
2) check/clean all connections in the start circuit.
3) bypass the start circuit and " hot wire " the starter to ensure the starter is not the culprit.
Come back with your questions/results.
Old Jul 20, 2013 | 05:56 AM
bagga's Avatar
bagga
my 85 has been doing the same thing since it was new in 85. does it always start after the pause? if it starts it ain't broke. if it ain't broke, don't fix it.
Old Jul 20, 2013 | 10:53 AM
traxster's Avatar
traxster
Yes it starts after the pause... im going to try some things thats wierd it did that bagga the whole time, i noticed on another fltc it fires and starts rite away...
Old Jul 20, 2013 | 06:40 PM
texashillcountry
Dirt don't hurt
I have no idea what you are trying to say!!
Old Jul 20, 2013 | 06:43 PM
Stiggy's Avatar
Stiggy
It "pauses" when on a compression stroke and then "pushes" through it and then fires right up? Is that what you're saying?
Weak battery, older starter, timing advance.......
Old Jul 21, 2013 | 02:21 AM
citytrucker26's Avatar
citytrucker26
It is a common issue. Just have to have a little patience. If you want to check something, take your ignition out. look at the back of it for grease that melted down to the terminals. clean them off. Probably will fix the problem. Did on my FLHS. Now, the FXR still does this once in a great while. Not enough to worry about it. Plus I was chasing other gremlins when I found that. Another thing to do... ground your turn signals with a wire to the frame in the back. Will save your turn module. Harley has the ground going thru the housing to the fender to the frame... My module bit the dust which got me to ohming out circuits. Its not hard. Just run a wire from one of the bolts on the back of the light bar to the bolt that mounts the fender to the frame. Had an excellent right turn with the module when this was complete. Ended up making my own harness with 2 flashers installed. One for each side. Made it so if I ever came across another module, just plug it in. Good luck! Trucker Gary
Rick L
Electrical/Lighting/Alarm
Jun 10, 2018 09:51 PM
tvr
Nov 14, 2016 10:23 AM
union865
15
Apr 29, 2016 04:41 PM
kingkingking
Sep 29, 2009 06:28 AM
glide1996
May 28, 2007 01:39 AM
