Turn signals
The instructions with the unit are no good for Dynas and Softies but I have the correct diagram that I can send anyone who wants to use one.
BADLANDS T-SIGNAL AUTO CANCEL10PIN - ATS-03-A
by Badlands Motorcycle Products
5.0 out of 5 stars See all reviews (2 customer reviews)
List Price: $83.95
Price: $62.57
List Price: $83.95
Price: $62.57
My diagram is for Dynas and Softies, FL instructions come with the kit but if you can't make head nor tail of them, here are the Dyna/Softie Sporty connections:
You might have two flasher units and the Badlands instructions cover that but you can bypass both of those units and wire as below.
First locate your OEM flasher module, depending on the year and model of the bike it could be under the seat,under the tank-mounted speedo housing or behind the left hand side cover.
Cut off the stock plug where the original module connects with the bike’s wiring loom.
Connect the wires from the new module to the wiring loom as per the table below (Soldering and heat shrink is best).
If you don’t want to cut off the plug then just follow the wires back up the loom and connect into those wires with a scotch lock, crimped connector or solder.
Bike Loom.......................................... Badlands Module
Orange ...................................Red
Black.................................... .Black
White/Purple Stripe .................Purple
Purple ...................................Grey
White/Brown Stripe ............... Brown
Brown ..................................Yellow
White/Green Stripe ............... Ignore and tape
White/Green Stripe is speedo input and the Badlands module does not use speedo input.
I bought it because of the touch and release turn signal and self-cancelling feature but the fact that it also gives you the ability to use your turn signals as emergency flashers made it a no brainer for me.
I don't get it my OEM one has all the features you are talking about.
What year is your bike?
Was it like that from new or did the module wear out?
