Turn signals
Old Jun 29, 2021 | 09:12 PM
  #61
Heritage8's Avatar
Heritage8
Stage II
Originally Posted by Spanners39
My diagram is for Dynas and Softies, FL instructions come with the kit but if you can't make head nor tail of them, here are the Dyna/Softie Sporty connections:
You might have two flasher units and the Badlands instructions cover that but you can bypass both of those units and wire as below.
Badlands Flasher Module Wiring Instructions for Evo and TC Dyna andSoftail up to 2000 and Evo Sportsters to 2000
Read fully before you start!!!
First locate your OEM flasher module, depending on the year and model of the bike it could be under the seat,under the tank-mounted speedo housing or behind the left hand side cover.
Cut off the stock plug where the original module connects with the bike’s wiring loom.
Connect the wires from the new module to the wiring loom as per the table below (Soldering and heat shrink is best).
If you don’t want to cut off the plug then just follow the wires back up the loom and connect into those wires with a scotch lock, crimped connector or solder.
Bike Loom.......................................... Badlands Module
Orange ...................................Red
Black.................................... .Black
White/Purple Stripe .................Purple
Purple ...................................Grey
White/Brown Stripe ............... Brown
Brown ..................................Yellow
White/Green Stripe ............... Ignore and tape
White/Green Stripe is speedo input and the Badlands module does not use speedo input.
What if you dont have a flasher module at all ? what if you just have a flasher relay (1988 Heritage) then where do i connect the wires to?
Rancid17
Jun 23, 2012 08:43 PM
thetileman
Mar 4, 2011 11:03 PM
aztecfatboy
General Topics/Tech Tips
Nov 24, 2009 12:56 PM
bmanchee
Aug 14, 2008 08:48 PM
mthomas000
Apr 19, 2006 10:16 AM
