While I have the front wheel off for a new tire I figured I would make the most of it. Did the routine maintenance stuff like pack the bearings, replaces the seals, and clean/inspect the brakes (boring, I know).
I also polished the wheel and painted the fork lowers. Forks were relatively easy, a good sanding and several coats of epoxy. The wheels were a little more involved. Several hours of sanding with various grits to remove the machined finish, and then a good polish w/ some Mother's. Both turned out pretty well, I think. Gonna try to get even more shine out of the wheel, though. Enough blabbing, here's some pics.
Wheel/forks before:
And after:
