Spark Plug Observation.
Old Sep 10, 2013 | 05:06 PM
Spanners39's Avatar
Spanners39
I use Iridium plugs, you never have to take them out so it isn't an issue
Old Sep 11, 2013 | 07:31 PM
machinehed's Avatar
machinehed
Default Iridiums are the very best .
Iridiums will go for years and they are the best value .
I am a little confused about your post though so i will offer this...
Do not run any plugs that you are not sure of ?
The depth of the plug and its heat range must be compatible with your motor.
If i understand correctly , you are wondering why you have carbon on the last few threads of the plugs ? If this is true i suspect your plugs are incorrect for your motor and you are probably very lucky that the pistons did not hit the plugs and cause you a world of hurt .?
Many sites available to ensure you crossover the correct plugs for your bike.
Old Sep 11, 2013 | 08:29 PM
FlyingSpur's Avatar
FlyingSpur
You can measure the depth of the plug hole using a grip gauge. It's actually used for aircraft. If you can't find one PM me and I will get you one.
Here's a good one.
Aircraft Tool Supply Hi-Lok Grip Gauge: Amazon.com: Industrial & Scientific Aircraft Tool Supply Hi-Lok Grip Gauge: Amazon.com: Industrial & Scientific
Old Sep 11, 2013 | 09:09 PM
Slammed-N-Senseless's Avatar
Slammed-N-Senseless
'86 EVO, stock heads. I run NGK BPR5ES and Autolite 4265 with carbon on the first 1/4" or so on both types of plugs. Curious, I googled "harley evo sparkplugs" under images and nearly every used set had the same signature. I'm not saying there is anything wrong as these are the plugs spec'd just curious why and how it would run with standard thread plugs and if anyone else has tried it?
Old Sep 12, 2013 | 08:40 AM
Schex's Avatar
Schex
Here's some good info on reading plugs, will explain the color you see on the threads.
http://honda-tech.com/showthread.php?t=3063102
Old Sep 12, 2013 | 09:11 AM
Slammed-N-Senseless
Wow, now that's a great read, I've never seen an article on how to read spark plugs so informative, thanks for sharing. I've also been reading my heat range wrong and timming. I'm glad I made this post, I almost didn't.
jackhis
Aug 12, 2019 11:09 AM
jbyun
Aug 11, 2019 10:07 PM
acedantinne
Sep 17, 2007 12:16 AM
alaskajeff
Jun 13, 2007 04:17 PM
Shift_4lo
Mar 11, 2006 03:37 PM
