S&S cable guide breaking
Old Sep 16, 2013 | 08:23 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
FWIW mine go up between the tank and the frame.
If they are pulling either way you route them that makes me think they are too short or too thick.
Obviously it ain't right but I'm having a hard time visualizing what is happening.
Old Sep 16, 2013 | 08:29 PM
Kickstand03303's Avatar
Kickstand03303
Could you post some pictures so I can see how yours looks?
Old Sep 16, 2013 | 08:31 PM
Slammed-N-Senseless's Avatar
Slammed-N-Senseless
OK, a couple of things come to mind; Have you ever tried to operate the butterfly by hand without the cables attached? It's highly unlikely the problem is there, but just a thought. Also, 14" Apes, what about the risers, how tall are they and do you know the length of the cables your indi put on?
Old Sep 16, 2013 | 08:38 PM
texashillcountry
Dirt don't hurt
I'll try but I ain't so good with a camera.
Give me a few minutes.
Old Sep 16, 2013 | 08:39 PM
Slammed-N-Senseless
Mine runs between the tank and frame also.
Old Sep 16, 2013 | 08:49 PM
texashillcountry
Dirt don't hurt
Here they are.
Do they help?
Attached Thumbnails S&S cable guide breaking-cables-004.jpg   S&S cable guide breaking-cables-005.jpg
Old Sep 16, 2013 | 09:00 PM
texashillcountry
Dirt don't hurt
One test to see if your cables are too short is to start your bike, stand it up, then rotate your handlebars all the way right to all the way left. If the rpms change you need longer cables.
Old Sep 16, 2013 | 09:12 PM
gump305's Avatar
gump305
WOW look at all that dirt, TD will be by to clean it for ya!!
Old Sep 16, 2013 | 09:16 PM
texashillcountry
Dirt don't hurt
Nope the dirt is holding it together!!!!!!
If I let TD clean it I would be missing parts in no time!!!!!!!
Old Sep 16, 2013 | 09:37 PM
texashillcountry
Dirt don't hurt
Hey Kickstand after looking at your pictures again I think the problem is in they type of cables you are using.
Looking at your pictures it looks like the cable ferrules aren't fitting down inside the cable guide. That effectively makes the cable guides longer and then they can't fit under the tank.
Can you look at the cable guide when you twist the throttle and see if you can see any movement.
