S&S cable guide breaking
Old Sep 17, 2013 | 08:07 AM
Kickstand03303's Avatar
Kickstand03303
Originally Posted by texashillcountry
Hey Kickstand after looking at your pictures again I think the problem is in they type of cables you are using.
Looking at your pictures it looks like the cable ferrules aren't fitting down inside the cable guide. That effectively makes the cable guides longer and then they can't fit under the tank.
Can you look at the cable guide when you twist the throttle and see if you can see any movement.
It does look like they are not sitting all the way down, i will have to check that out tonight. I appreciate all your guys help!
Old Sep 17, 2013 | 08:38 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Let us know what you find.
Did the pictures I posted help any?
Old Sep 17, 2013 | 08:18 PM
Kickstand03303
Yes the pictures helped and Yes where the cables go into the guide doesn't seem right at all. I think you guys are right, it has something to do with the cables. I will post pictures tomorrow night, been to busy and now getting ready to watch SOA...lol
Old Sep 17, 2013 | 08:32 PM
Barbarossa's Avatar
Barbarossa
When I got my S&S V111 it came with two guides, one for the stock cables and the other which was on the carb for (I guess) S&S cables. You may have to get the guide for the stock cables which had wider and lower guide tubes.
Old Sep 18, 2013 | 08:27 PM
Kickstand03303
If I use the cable guide you are talking about I don't think my cables would work. I think the actual cables would be to long. I only got one cable guide with my carb.
Old Sep 18, 2013 | 08:30 PM
Kickstand03303
Here are some picture of my newly routed cables. I think it elps but the throttle still pulls hard.
Old Sep 18, 2013 | 08:36 PM
Kickstand03303
Texas you can see in the first picture what you were talking about in the first picture where the ends of the cable aren't sitting all the way down in the guide but I cant get them down any further. So you guys are right about something not matching up. So I am not sure what cables I need. Sucks because I paid a lot for the ones that I have. So any help would be great!
Old Sep 18, 2013 | 08:50 PM
texashillcountry
Dirt don't hurt
Maybe it's just me but those cables look entirely too tight to me.
Did you do the test in post #17?
Who made the Cables?
Are they Barnett or what?
Do you have the star screw throttle lock?
Check to make sure it is loose.
That's all I got right now.
Old Sep 18, 2013 | 08:52 PM
Dr.Hess's Avatar
Dr.Hess
I don't think your cables are long enough, for one thing.
Old Sep 18, 2013 | 08:53 PM
LowriderHarold's Avatar
LowriderHarold
Default 2 Types
http://www.jpcycles.com/product/400-230
http://www.jpcycles.com/product/400-684
S&S makes 2 types of guides. Which one you use, depends on what type of cables you use. Looking at your pic, you may have wrong one because you have too sharp a bend going into the guide. If its hard to pull, don't ride it until you get it fixed. You may have the throttle stick & crash.
hth
Ride Safe,
Harold
