Not starting
Old May 22, 2014 | 10:03 PM
  #41
1960lespaul's Avatar
1960lespaul
So I pull about open the casing on the Run/Off & Start button. And I naturally drop the little screw that holds the wire to the top casing into the bottom half of the casing and under the handle bar. Typical me. But if I grab that wire and push down or pull towards me the brake light kicks on. Pull up or away has no effect.
Old May 22, 2014 | 11:27 PM
  #42
Spanners39's Avatar
Spanners39
You are probably disturbing the brake light switch in the housing when you pull the wires.
AtlasMick
Mar 15, 2017 06:26 PM
PierreG
Sep 22, 2015 07:04 PM
CajunSausage
Feb 15, 2014 08:39 AM
SportyPig
Jun 4, 2010 06:02 PM
GONZEE
Electrical/Lighting/Alarm
Apr 18, 2009 08:45 AM
