fxr primary leak
Old Sep 22, 2013 | 03:25 PM
mike14_07's Avatar
mike14_07
Default fxr primary leak
put my fxr together last week, road it it leaks primary fluid from the solenoid like crazy, took it apart found the boot (mine has the updated with a cup on the solenoid end) was waded up. the closest stealer had one, picked it up replaced it. got it all together rode it this morning same thing. bikes an 88 fxrs upgraded to splined main shaft and a 92 clutch, everything else is 88.
Old Sep 22, 2013 | 03:36 PM
Spanners39's Avatar
Spanners39
Too much primary fluid maybe? Is the gasket OK?
Old Sep 22, 2013 | 03:56 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
A friend of mine has an '85 FXE and he made a big deal of getting the right gasket for his starter solenoid one time.
Apparently they make different ones.
Are you sure you have the right one?
Old Sep 22, 2013 | 04:30 PM
mike14_07's Avatar
mike14_07
its a factory harley one, looked like the same one that was in my bike. im confused as to how so much is coming from there in the first place. i had a tiny leak from there till i got a new spyke solenoid then it got retarded. but the seal was all wadded up.
Old Sep 22, 2013 | 06:06 PM
texashillcountry
Dirt don't hurt
Are you saying your troubles started with the spyke solenoid?
If so check for your problem there.
Old Sep 22, 2013 | 08:36 PM
mike14_07's Avatar
mike14_07
not so sure. i had the same leak before just minor.
damager1
Oct 7, 2017 04:25 PM
dirtbag1
Sep 5, 2012 05:29 PM
Bama91
EVO
Apr 6, 2012 01:27 PM
btroy
EVO
Jan 30, 2012 02:57 PM
hoodlum
Aug 12, 2008 05:50 PM
