Making a list, checking it twice. ...
Old Sep 28, 2013 | 11:21 PM
Spanners39's Avatar
Spanners39
Originally Posted by bluharley
One shop owner told me those things will go out of round when hot at higher rpms and self destruct. When I first got my bike, the first time I was it there, it was a disaster. The casing was gouged out around it, and the breather was trashed. If it's supposed to save the case, it didn't do a very good job on mine.
I can't see how they can go out of round at high RPM....I am thinking that centrifugal force and the hole in the case would keep it real.
Old Sep 28, 2013 | 11:31 PM
HarDlife's Avatar
HarDlife
Originally Posted by Spanners39
Its a potential "oil thread" so best to make up your own mind, I have never seen a nylon one cause damage but I haven't worked on every Harley on the planet (yet)....I think the bike mentioned above might have ingested something through the breather that it was metal but I wasn't there so can't comment.
You MUST replace the wrist pin circlips if you have removed them, you can't reuse them and have a motor that keeps running.
If the pinion keys have no wear or grooves in their sides then you can reuse them.
And some people swear by adjustable pushrods, whereas I think they are the work of Satan....
Do the research, read the posts and decide for yourself is all I can advise.
Yeah, I think I might have opened a can of worms with some of my questions.
(I agree about PRs, btw)
Old Sep 28, 2013 | 11:45 PM
Spanners39's Avatar
Spanners39
Can of worms or not, its good to air these things, some aftermarket stuff is totally misrepresented and people will tell you anything to take your dollars off you.
Old Sep 29, 2013 | 07:31 AM
Scratt's Avatar
Scratt
Making a parts list for the rebuild, have questions.
Would like to use an EV 27, but I've read about noise and increased wear on valvetrain, true or false? I mainly ride solo, in/around town, semi-aggressive riding style w/ occasional 2 up, no gear, back roads. I don't wanna beat the lifters up. 27, or something else? Gonna reuse stock PRs. Torrington, of course.
Lifters. Stockers seem okay and have alleged 14k rough miles on them. Go ahead and replace? Best low budget choice?
Breather gear. As some may recall I have some very light scoring in bore. Should I go stock nylon, steel rotary, or reed breather?
Heads, cylinders, pistons, and rings seem perfectly fine. Gonna run 'em.
Gaskets/seals. Obviously, going to replace the one that were destroyed. What about rocker, PR tubes, and primary, they look really good, replace 'em anyway? Just get a top-end kit? Cometic? .030 HGs? Best case sealer?
Carb. Was gonna rebuild/re-jet while off. I was thinking 45 pilot/180 main would be a good start w/ EV27 or similar cam, yes? Any other carby tweaks? Green Performance filter/ drilled breather plate for better breathing. Already have SE slip-ons.
Anything else?
Are you going to start a build thread? If you do or add pics as you go to another thread I would like to see how you do and if anything was a bitch.
Thanks
Old Sep 29, 2013 | 08:56 AM
Hackd's Avatar
Hackd
In 18 years of running one, I haven't had any issues with the EV27 cam. A better cam IS one of the necessary improvements to any EVO. IMHO.
Free flowing air cleaner, free flowing exhust (note, that doesn't always mean ear splitting loud), and an upgraded ignition. All will make the EVO run like it should've run from the factory.
Old Sep 29, 2013 | 09:31 AM
HarDlife's Avatar
HarDlife
Thanks
I will definitely start a thread once I get started, and of course there will be pics! I know how you pervs like to watch!
Good to know, Hackd. I already have an SE module/SE wires. I assume that is sufficient for my build, correct?
Old Sep 29, 2013 | 09:58 AM
1/2crazedbikr's Avatar
1/2crazedbikr
Default V Thunder cam???
Hey Har D,
I know many guys on this forum have talked about the V Thunder line of cams-have you given those a look?
They say they emphasize reducing valve train clatter when they design their cams, which is one of the things you mentioned is important to you.
I will be replacing cam, lifters and some other things after I get my son married off next week, and I am leaning toward the EVL-3010 for my "stripped down" Electra Glide. They also have the advantage of selling their cams with or without the pinion gear in case you are planning to reuse your old one for less gear whine. Saves you some coin both in the initial purchase and possibly at the machine shop (don't have to remove the new pinion gear from the new cam).
Obviously they have a wide selection of different grinds that would likely be suitable for your ride...might be worth a look.
Old Sep 29, 2013 | 11:47 AM
cpbedor's Avatar
cpbedor
for what it's worth, I also run a EV27 and it's great. No issues, just fun.
Old Sep 29, 2013 | 11:53 AM
HarDlife's Avatar
HarDlife
Originally Posted by 1/2crazedbikr
Hey Har D,
The evl-3010 was my other consideration, along with an EV13. I want to get the most bang for my buck, without taking life off components. The 3010 is tempting. I found the evl-3010ng for $87 bucks, have you seen it cheaper anywhere?
Old Sep 29, 2013 | 12:04 PM
traildog's Avatar
traildog
Had a 3010 in my FLHTC. She ran great! And was NOT noisy in any way.
