Bad Vibration... help
Old Oct 12, 2013 | 07:47 AM
Turbo38gn's Avatar
Turbo38gn
Default Bad Vibration... help
Morning folks,
I have a 1988 FXLR-C, 98" motor, been just a great rider for years. I recently was on the way home and as so often happens.... I turned onto the main drag.... and guess what happens next.. Bang... 1st, 2nd and click 3rd... what a rush!! Everything seemed fine, get to the next light and stop, take a left and begin to accelerate normally, or maybe I should say normally for normal drivers, as I reach around 3400rpm, a wicked vibration comes over the bike, I can feel in the grips... I back off try it again... same thing. So I pull in the clutch, give it a rev, nothing, feels fine. Only does it under load. I have checked motor mounts, chain, sprocket, just took the primary cover off, chain is a pretty loose, I removed the pressure plate and clutches, the hub is tight on the trans input shaft, the empty clutch basket has lots of movement.
Any ideas, I can't see it in the motor, but is that possible... I'm going to look for my shop manual now to see if there is any info on the clutch basket play..
Thanks ahead for any help or suggestions..
Old Oct 12, 2013 | 09:06 AM
Tom84FXST's Avatar
Tom84FXST
More than likely, the front motor mount is toast or the top mount is broken...you just can't see it...pretty easy to remove and inspect.
Old Oct 12, 2013 | 09:59 AM
Turbo38gn's Avatar
Turbo38gn
Thanks Tom, I checked both out closer. The top is definitely fine and I just removed the lower, I could pry the motor up with my pry bar before removing, have the mount in my hand, it's not broken or rubber torn, but no doubt had 1\4" of upward MOVEMENT.. seems when the bad vib started, it was sudden, after a full out 6,000rpm 1-2-3 shift.
Just a little more info, I recently had a rear tire replaced and the bike was hooking better than ever. The old tire, although not worn much was just dried up and spinning easily on the hard hits. The new Avon is like glue.....
I keep flashing back to a crank pin...? wheels out of balance...
Old Oct 12, 2013 | 07:30 PM
machinehed's Avatar
machinehed
Default vibes.
You are a hard rider as described by your 6000 rpm launches ? I would suspect an off center wheel after the tire replacement , unbalanced wheel/tire , or possibly worn motor mounts that are showing there age after the new " sticky " tire has been installed.?
Old Oct 12, 2013 | 08:44 PM
Turbo38gn's Avatar
Turbo38gn
I'm with you, I was looking at the wheel weights this morning, could see where there were some, but I'm thinking that was the spot for the old weights...
Does anyone know how much play is in the outer clutch basket with the clutches removed? I have lots of movement...
Old Oct 12, 2013 | 11:38 PM
Spanners39's Avatar
Spanners39
It depends on how you define "Lots"....more than a few mm at the outer edge is not good.
Old Oct 13, 2013 | 08:17 AM
Turbo38gn's Avatar
Turbo38gn
How about 3\16".....
Old Oct 13, 2013 | 01:22 PM
Spanners39's Avatar
Spanners39
Not good, check hub bearing.
BigRedUltra
Apr 5, 2017 10:07 AM
apetterez
Apr 5, 2015 09:23 PM
keepriding
Sep 24, 2014 06:16 PM
mario medeiros
Jul 4, 2011 06:53 AM
sm0kediver
Jun 14, 2010 12:39 PM
