Another MM EFI vs Carb thread
Old Mar 5, 2014 | 03:52 PM
  #101
IBDAGRIZ's Avatar
IBDAGRIZ
Pick up a set of these. Makes it way easier to remove/install the setup.
S&S CYCLE 17-0486 EARLY TO LATE STYLE BREATHER CONVERSION KIT
Griz
Old Mar 5, 2014 | 11:55 PM
  #102
Road Star's Avatar
Road Star
Success!
plugged in the Daytona Twin Tec ignition module and coil, mounted the carb, hooked up the choke... and... it runs!
Still need to get a throttle cable and mount the tank, etc, but it works.
Very relieved!
Going to have to use the dented tank until I can get my EFI tank modified. Not looking forward to that.
Old Mar 9, 2014 | 08:13 PM
  #103
HGM's Avatar
HGM
Rather than starting a new thread, thought I'd throw some updates in and sort it all out later if I decide to do a build thread.. Front end is about done, I decided to cut the axle down and drill a hole for the speedo drive. Actually used a smaller one from a narrow glide and mock's up pretty nicely. I'll give a full report after some miles, but I see no reason for it to have an issue. The 1" axle just needed a trim to 3/4" on the end..
Attached Thumbnails Another MM EFI vs Carb thread-resizedimage_1394413089977.jpg   Another MM EFI vs Carb thread-resizedimage_1394413090967.jpg   Another MM EFI vs Carb thread-resizedimage_1394413119476.jpg   Another MM EFI vs Carb thread-resizedimage_1394413169808.jpg   Another MM EFI vs Carb thread-resizedimage_1394413188255.jpg
Old Mar 9, 2014 | 08:15 PM
  #104
HGM's Avatar
HGM
Couple more of the FE
Attached Thumbnails Another MM EFI vs Carb thread-resizedimage_1394413187558.jpg   Another MM EFI vs Carb thread-resizedimage_1394412509082.jpg
Old Mar 9, 2014 | 08:27 PM
  #105
HGM's Avatar
HGM
I also did the rear swing arm.. Everyone who has done it seems to be doing so with a rear wheel in mind... Well, for a definitive answer, the rear swing arm will not work with the original belt and pulley.. Couple things to remember, the new SA will take a 1" axle. Since you need the axle, you will need a wheel and pulley. This also requires a belt. So, while there, may as well go 1-1/8".. I used the Motorcycle Metal kit, pretty easy to do, just labor intensive on the belt side.. A socked and 1/2" extension and ball joint press were all the extra tools I needed.. Here's a few of what I've done so far..
Attached Thumbnails Another MM EFI vs Carb thread-resizedimage_1394412406614.jpg   Another MM EFI vs Carb thread-resizedimage_1394412405486.jpg   Another MM EFI vs Carb thread-resizedimage_1394412376382.jpg   Another MM EFI vs Carb thread-resizedimage_1394412360712.jpg   Another MM EFI vs Carb thread-resizedimage_1394412361123.jpg
Old Mar 9, 2014 | 08:28 PM
  #106
HGM's Avatar
HGM
Size comparison.
Attached Thumbnails Another MM EFI vs Carb thread-resizedimage_1394412376809.jpg
Old Mar 16, 2014 | 08:48 PM
  #107
Road Star's Avatar
Road Star
Not sure what I need to do with my tank. I removed the fuel lines; what do I do now?
Looks like this may be it?
http://www.pingelonline.com/magneti_...conversion.htm
Just plug one hole and put an adapter in the other?
My tank is from a 2001; running a different tank in the meantime.
Old Mar 16, 2014 | 09:02 PM
  #108
HGM's Avatar
HGM
Yea, you twinkie guys have it easy.. Put the plug in the front and petcock in the rear so you have more room..
Old Mar 16, 2014 | 09:04 PM
  #109
Road Star's Avatar
Road Star
Cool - Thanks. I was concerned about the raised part inside the tank; I thought that needed to be removed.
Old Mar 16, 2014 | 09:11 PM
  #110
HGM's Avatar
HGM
Nah, that's the fitting the adapter screws into.. In the grand scheme of things, its not that large and wont affect the fuel supply.. You're good..
